Hi i have just found a mrf 454 in a old fuse box i have if i remeber it was pulled from a radio that had been crushed on the front so i asume its a worker how would i check if it is ok.
And more to the point what apps would it be used for linear i assume but to what power and is it any use keeping
how do i check a final is working
- Call Sign: 2e0dxi
Kenwood ts2000e heil studio mic
altron 12m mast tailtwister rotor
hygain th3 mk3 triband/cushcraft 3 ele 6m/2x9 element 2m
gainmaster/x510 whitestick
jaybeam airband vertical
- Corblimeyguvnar
- Call Sign: 26TM097
- flickpot
- Call Sign: 163TM230
Re: how do i check a final is working
I have also some that was taken from radios in the past, great to find if there working or not.
163-TM-230
163-FB-230
163-FB-230
For a quick test you can use your meter set on diode test.
If you look at the transistor (pill) as a full wave bridge rectifier and test each diode in turn,
this will tell you if there is a short or an open circuit on any of the diodes.
You have to remove the transistor to do this test.
Other than that you'll have to wire a short piece of wire to each terminal and use the HFE facility on the meter, if it has one, to determine it's gain, anything higher than about 15 and it should be a working one.
