Anyone know what bit to twiddle inside a Cobra UK25LTD ST to lower the power output.
Mines currently doing nearly six watts, but need to lower it to below 4 watts to drive an amp.
Thanks,
Curny
Cobra UK25LTD power output adjustment??....
- curny
Curny
163-TM-336
163-CT-336
'UK Three Thirty Six' on midband AM
163-TM-336
163-CT-336
- Arby80
Re: Cobra UK25LTD power output adjustment??....
Don't have a schematic but adjust L10, L9 and L8 for RF Output.
(taken from somewhere on the net)
26 TM 380 "The Watchman"
Scanners -:- Ubc3300xlt & Ubc9000xlt
CB Radio -:- Midland 278 & Superstar 3900EFT
VHF Radio -:- Jing Tong JT-208
PMR446 -:- Binatone Action 950
SW Receiver -:- Yaesu Frg-7
Working Base Antennas -:- Royal Discone 2000 & Sirio GPS27
- curny
Those are for the US spec AM radiosArby80 wrote:Don't have a schematic but adjust L10, L9 and L8 for RF Output.
This is a UK25LTD - totaly different guts.....
Curny
163-TM-336
163-CT-336
163-TM-336
163-CT-336
- Arby80
It was quoted as being for the LTD as wellcurny wrote:Those are for the US spec AM radiosArby80 wrote:Don't have a schematic but adjust L10, L9 and L8 for RF Output.
lol, big pimp doesnt like these rigs too much
http://citizensbandradio.org.uk/forum/i ... opic=848.0
Am curious though, all the specs say its a 4w rig? how is yours doing 6?
I do know these radios have a 2SC1969 output worth swopping for a cheap 4W one!!
- Dragonfly
- Call Sign: 26TM363
- Clint
- Call Sign: 26TM360
Arby the inductors never reduce output as such just detune the frequency trap, only ever adjust these if you either have a bandpass watt meter or a spectrum analyser. For instance you can nearly always get more watts displayed on a watt meter by tweaking these but almost never on the band you want the power on, this leads to interference and also extra heat that can kill and will deteriorate the final transistors over time.
26-TM-360
Old 80's Radios and lots of them - Vintage Computers especially late 70's C=PETS
- curny
Perfect!!Dragonfly wrote:Only have the uK29LTD in me scribble pad but may use the same board as the UK25LTD , If so then RV202 is the power adjuster .
Yes, board is the same for 25 and 29
Thanks Dragonfly
Curny
163-TM-336
163-CT-336
163-TM-336
163-CT-336
