2sc2166 replacement
- alexthegasman
2sc2166 replacement
could anyone tell me the best direct replacement for one of these transistors please? it's to go into a galaxy pluto, dual 2sc2312 outputs. The two finals are showing ok on my dmm, using the diode test method, but the driver is showing a short, so i'm suspecting this to be the problem (only 2 watts output). everything else on the radio works ok. Thanks for looking
All the big numbers, alexthegasman, 26tm645
Ham radio is a hobby, c.b is for life!!
- Call Sign: 29VLF125
Re: 2sc2166 replacement
Hi Alex
the eleflow 2sc2166 from weazle66 on ebay
i have used them and some of the other eleflow transistors and have had no problems with them.
Ray
Ray
Techquest AKA Jedi
Av101 Astro Plane Old Imax n Loads of Radios
Mmmmmmmmmmm ADAMS n other Presidents
- 26WD40
Maybe these are the real deal, worth taking a chance. Make sure you pay by paypal though in case they could be fakes.
http://www.ebay.co.uk/itm/2SC2166-NOS-G ... 4744079034
gholdq on youtube.com
26TM265
26FB165
26CT066
26UK165
26TM265
26FB165
26CT066
26UK165
- Clint
- Call Sign: 26TM360
Queball wrote:Maybe these are the real deal, worth taking a chance. Make sure you pay by paypal though in case they could be fakes.
Yep just buy a real one, I have loads.
26-TM-360
Old 80's Radios and lots of them - Vintage Computers especially late 70's C=PETS
- alexthegasman
Thanks all for the advice, i've seen one or two of weazle's vids, and it seems he swears by 'em. I'll let you know how i get on. Just one other thing, i had this radio in not for the power problem, which was discovered later on, but for the freq counter which was flashing zero's for a few minutes before reading properly. Turns out it was R625, a 56ohm on the back of the board which had gone low value. Just in case anyone else has this issue. Thanks again for the info.
- 26WD40
check the feed back he has only sold 1 thing !!!! yet weazle66 has 1429 @ 100% i know where i would buy from !
REAL RADIOS GLOW IN THE DARK !
26TM1540
SAM KETTERING
26TM1540
SAM KETTERING
- alexthegasman
i did check out the feedback, sort of habit i suppose!!! we all have to start somewhere i suppose, still, i'm grateful for any advice
- Clint
I have read on a couple of forums the replacement 2166's are hard to set-up and also don't last as long, just fit an original they are easy to source no need for alternatives.
26-TM-360
- alexthegasman
where do you get yours from Clint? have you got a trusted seller, or do you fancy selling me 1 or 2 from your own stocks??Clint wrote:I have read on a couple of forums the replacement 2166's are hard to set-up and also don't last as long, just fit an original they are easy to source no need for alternatives.
