Anytone at5555 hidden menu.
- listner132
Is there a hidden menu on this radio ? mines is version 3.1.
thanks.
thanks.
- UGLY_BOB
Re: Anytone at5555 hidden menu.
I don't know for sure. There is supposedly a secret menu on the V3.1- but I've never tried it.There's a whole bunch of information about that sort of thing on the Charlie Tango forum. You might do well to give that lot a read.
http://s3.zetaboards.com/copythat/topic/7538099/1/#new
The link may not work unless you are a member... but it's a great forum worth joining anyway.
Ugs
Ugs
EXTREMELY WEIRD... AVOID AT ALL COSTS !
- astradyne
A few extra menu settings were added on the v4. However the booklet provided wasn't re-printed to suit the new functions of the radio. Very confusing at first, but I think the v4 has two extra menu options added on top of the v3.
- listner132
joined ct site..thanks for the info guys.
still dont know why these radios are not properly set from the factory.
- Viper
Having read the CT thread I'm left pondering why he didn't just get his friends to adjust his radio, since they had obviously done theirs successfully
power on pressing func then press RB ANL DW the next three buttons in a row then you get to the alignment page for the AM/FM USB LSB offsets. so if yours is slightly off alter these remembering what they were (alter with clarifier) power off to save. worked fine for my v3.1
no responsibility to damage it
- listner132
All done took me an hour or so to get spot on + or - a few hertz.MARKASTERIX wrote:power on pressing func then press RB ANL DW the next three buttons in a row then you get to the alignment page for the AM/FM USB LSB offsets. so if yours is slightly off alter these remembering what they were (alter with clarifier) power off to save. worked fine for my v3.1
thanks for your help again guys.
- listner132
I took this from the charlie tango web site.
Calibration on AT-5555
> Adjustment:
> Press and hold "FUNC" while powering on the radio; then press "RB" once, then press "AN/ANL" once, then press "DW" once, the radio enters adjustment mode when the LCD displays BFXXX, (where XXX is the numeric setting value) and you must make adjustments to the frequency in each mode, one by one:
> A. Switch to CW mode. Adjust the CLARIFIER until the frequency counter shows 10.6950 MHz.
> B. Switch to FM mode. Adjust the CLARIFIER until the frequency counter shows 10.6950 MHz.
> C. Switch to USB mode. Adjust the CLARIFIER until the frequency counter shows 10.6925 MHz.
> D. Switch to LSB mode. Adjust the CLARIFIER until the frequency counter shows 10.6975 MHz.
is there a test point in the radio to hook up the frequency counter to get the 10.6 ? ? readings ? if so which one ?
thanks.
> Adjustment:
thanks.
- UGLY_BOB
I think the 'frequency counter' referred to in those instructions is the one shown on the LCD of the radio itself, not an external one.listner132 wrote: is there a test point in the radio to hook up the frequency counter to get the 10.6 ? ? readings ? if so which one ?
thanks.
Ugs
- listner132
sorry bob but it is not...there is no way that the internal counter is capable to read these sort of frequency's....UGLY_BOB wrote:I think the 'frequency counter' referred to in those instructions is the one shown on the LCD of the radio itself, not an external one.listner132 wrote: is there a test point in the radio to hook up the frequency counter to get the 10.6 ? ? readings ? if so which one ?
thanks.
Ugs
i got it all sorted now any way..took about 1 and a half hours but i got there in the end.
Hi Bob when in calibration mode it just comes up with numbers for reference.UGLY_BOB wrote:I think the 'frequency counter' referred to in those instructions is the one shown on the LCD of the radio itself, not an external one.listner132 wrote: is there a test point in the radio to hook up the frequency counter to get the 10.6 ? ? readings ? if so which one ?
thanks.
Ugs
Glad you fixed it. this is common on the older sets.
- Otter
- Call Sign: 26TM439
I was going to join once but they insisted on foisting a CT callsign onto me when I joined, so I didn't bother. One callsign is enough for me, and TM is just fine.UGLY_BOB wrote: http://s3.zetaboards.com/copythat/topic/7538099/1/#new
Ugs
Ho There my dx-5000 seems off freq (not under gtee) Whats the connection point for the freq meter please? any more guidance on setting up properly using clarifier?
thanks!
thanks!
- UGLY_BOB
The following info is courtesy of Nik Gnashers - I thought I'd chuck it onto here as Nik has made a good job of explaining.
UPDATE :
I decided tonight, with the help of 5 friends, to try and get my dx5000 to display bang on frequencey instead of 27.554-80 (when it was supposed to be 27.555-00 for example) by using the secret menu.
First, get the radio on the band you want to adjust (I did usb 1st), then :
To access the menu, turn the radio off, then hold the function button in and turn the radio on. Release the function button and then press the next three buttons along (rb, nb, dw) one at a time in quick succession.
The display should show bf xxx (xxx being a 3-digit number).
If your radio is like mine, and is low ie showing 27.55480 when its bang on 27.55500, then you need to adjust the 3-digit number down. My rig showed bf 168, and to get it bang on freq on 27.55500 on the display, I had to adjust the bf168 to bf130. The clarifier moves the last digit, and the channel change moves the middle digit.
The annoying thing though was - the 3-digit number only adjusts as low as 130 !!!
If I had needed to go lower to get my rig on, I wouldn't have been able to, so it is very lucky for me, that the lowest number setting (130) was just enough to put my radio on frequency.
I flicked to lsb and the display was bf868, which I adjusted down to 845 to get the radio on frequency.
Obviously the most accurate way would be with a frequency counter, but as I don't have one, I had to trust my 5 friends radios (and several different radios each too), and by process of trail and error adjust till everyone was happy.
Forgot to add, after adjusting the bfxxx number, you have to power the radio off and back on again to actually tx/rx again, as you hear nothing when adjusting in the secret menu.
Hope this helps others to get their radios displaying bang on the five's and zero's, it sounds complicated but really it isnt, and it only took me 30 mins to get all bands on frequency, so if yours is not displaying an exact 5 or 0 when its supposed to do, why not give the secret menu a try.
Its worth adding : always make a note of the starting values, and the final values, in case you need to reset the radio sometime, as I imagine the numbers will default back to original.
Nik
As Nik says - Make sure to note the starting number, just in case you make a mess, and have to go back.
Ugs
UPDATE :
Nik
Ugs
