Need help again
ian
Call Sign: 108SD121
Need help again
Post by ian » 10 Oct 2018, 11:06
Hi guys I need to tighten the antenna socket but don't have the right key. Can someone please tell me what the key is called it's a BNC antenna socket I need to tighten.
De Ian 108SD121 - 108ID121 - 108OP121.
ian
Call Sign: 108SD121
Re: Need help again
Post by ian » 10 Oct 2018, 14:37
It's the nut with the two slots opposite each other.
GusWroclaw
Call Sign: 161TM313
Re: Need help again
Post by GusWroclaw » 10 Oct 2018, 15:03
161-TM-313 - Midland Alan 42
DX-Digger
Call Sign: TM205
Re: Need help again
Post by DX-Digger » 10 Oct 2018, 20:02
try a pair of long nosed pliers ;-)
ian
Call Sign: 108SD121
Re: Need help again
Post by ian » 10 Oct 2018, 21:39
Can't get into it with pliers it's on my Albrecht hand held but thanks all the same.
Tim
Call Sign: 26AT239
Re: Need help again
Post by Tim » 10 Oct 2018, 22:31
If you can post a picture of the part you need to tighten down we might be better armed to advise you of the tool you need to find.
DX-Digger
Call Sign: TM205
Re: Need help again
Post by DX-Digger » 11 Oct 2018, 14:52
https://www.amazon.com/Stanley-84-096-5 ... 0001IW50Y/
These are what i was referring to long nose/needle nose pliers.
Re: Need help again
Post by The Collector » 11 Oct 2018, 19:14
Not sure if it'll help, but you can sometimes put a small flat screwdriver onto a tightening ring/nut and tap it round with say a small hammer to tighten it providing the tip of the s rewdriver can sit in a notch or similar. You can then tighten it a bit at a time even if you can only access a few millimetres.
If this isn't what you're on about, then I'll shut up now ;)
GusWroclaw
Call Sign: 161TM313
Re: Need help again
Post by GusWroclaw » 11 Oct 2018, 20:05
ian please check my message above. It was in the moderation queue and now it appeared above the other replies. I think that's the tool you are asking for.
