Cobra - 148GTL - Malaysia - PCB EPT014811Z
- cb4ever104
Re: Cobra - 148GTL - Malaysia - PCB EPT014811Z
Glad to hear you've almost got it fixed .
- electronicsmachine
- Call Sign: 1TM129
info for modified cobra 148Gtl ? thanks...
1 TM 129 -------- TANGO MIKE DX 11 METER GROUP ITALY Location: BRINDISI (SOUTH ITALY )-------------
Equipment Radio C.B. : President Jackson + Mic. Sadelta Echo Master Plus+ Ant. Lemm Vertical M5 5/8
- Especialista
- Call Sign: PU2REO
Look what my beauty has become!
Until Now:
Channel range from -150 to 150 (I know radio filters will block most of negative channels. I'll think about that later)
Frequency and Channel Modes.
Electronic roger beep
Electronic Voice lock, 10Khz range, 100Hz precision on any band.
Planned:
Replacement of all caps and some diodes.
Radio input amplifier for small signals.
MOSFET based power stage.
It's still under development on weekends.
Until Now:
Planned:
... and keep the tubes glowing!
- Tin soldier
Especialista wrote: ↑29 Mar 2023, 22:27 Look what my beauty has become!
Until Now:
Planned:
Molto bello
muito legal
Very nice
- Especialista
- Call Sign: PU2REO
What kind of info?
This one o'mine uses an arduino and a clock generator. Original VFO and PLL were removed, created a new VFO with the mentioned parts.
- Especialista
- Call Sign: PU2REO
Hello, community!
First of all, I wish you all and all your loved ones a magnificent 2024: May all of you be blessed even more than 2023.
I've decided to share the suff related to this thread with you, in case any of you want to give it a try.
A small video from the result:
In the movie description, you will find the GitHub Repo with schematics and source code!
Don't forget to give it a Thumbs Up/Star, if it is usefull to you!
Best of everything,
E.
Best of everything,
E.
