Anyone help with this ?
Classic
Post by Classic » 14 Jun 2017, 14:11
I have just installed a new irf520 transistor. When i key up the power starts to drop as the transistor heats i mean like with in 20 seconds it goes from 15 watts to under 10 watts is that normal ?
listner132
Re: Anyone help with this ?
Post by listner132 » 14 Jun 2017, 14:23
What radio have you fitted the 520 in too ?
Classic
Post by Classic » 14 Jun 2017, 14:37
listner132 wrote:What radio have you fitted the 520 in too ?
Hi it's in a amp rm 35
Black Spirit
Post by Black Spirit » 14 Jun 2017, 14:56
How much power are you putting into the amp ?, It must be kept below 4w, Also the Mosfet will burn up quickly if the gate voltage is too high [over 4v].
Classic
Post by Classic » 14 Jun 2017, 15:09
Black Spirit wrote:How much power are you putting into the amp ?, It must be kept below 4w, Also the Mosfet will burn up quickly if the gate voltage is too high [over 4v].
3 watts i've even tried 0.5 watts and it still does the same thing.
Classic
Post by Classic » 14 Jun 2017, 18:35
Black Spirit wrote: Also the Mosfet will burn up quickly if the gate voltage is too high [over 4v].
In transmit ?
Black Spirit
Post by Black Spirit » 14 Jun 2017, 19:31
In transmit ?
Yes
bigal68
Call Sign: 26fb806
Post by bigal68 » 15 Jun 2017, 19:42
Nick's bang on.... gate voltage is critical on mosfets, as is keeping it stable....
Alan 26FB806
Use it or lose it!!!!
Classic
Post by Classic » 19 Jun 2017, 10:39
Black Spirit wrote:
In transmit ?
Yes
Tested and the meter goes off the scale. Also when i tried the amp on a switch mode psu as soon asi keyed up it blow up. Now that has haqppened 2 times. It don't happen on the old psu which isn't a switch mode.
2E1IIP
Post by 2E1IIP » 19 Jun 2017, 11:49
Do you have a schematic for the amplifier?
What was the original transistor - is this a "mod"?
Why an IRF520? They are notoriously unstable for RF applications above 7MHz.
Classic
Post by Classic » 19 Jun 2017, 12:17
2E1IIP wrote:Do you have a schematic for the amplifier?
I was told i could use it in this amp no problem.
2E1IIP
Post by 2E1IIP » 19 Jun 2017, 12:24
Ok thanks I will look over it, but at a glance the gate voltage should never exceed 20V as it clamped with a zenner.
Classic
Post by Classic » 20 Jun 2017, 16:36
2E1IIP wrote:Ok thanks I will look over it, but at a glance the gate voltage should never exceed 20V as it clamped with a zenner.
So from the diagram is there anything i can change to get the gate voltage to 4 volts as black spirit recommended ?
2E1IIP
Post by 2E1IIP » 20 Jun 2017, 17:25
The MOSFET Gate is tolerant to +/-20V, the gate is clamped to a maximum of 20V with the zenner diode - I am not sure why it is failing - I would try a different device - is it genuine or a Chinese import?
2E1IIP
Post by 2E1IIP » 20 Jun 2017, 17:27
Also check the gate voltage with a DVM and an FM carrier not exceeding 5W, check the diodes and the zenner diode to be sure.
Users browsing this forum: Google [Bot] and 3 guests
