Both Fantastic replies Simon & Adriano, well worth your time and effort. It is a pity that he is no longer looking here but that may change, if i hear him on I will point him back to these posts.
I don't personally belive that the posts in question had anything to do with hold or not holding a licence, it was about cheeky comments that were not required by any stretch of the imagination. Even after passing a foundation licence there are going to be mountains of experience required to further the hobby, not everything learned is retained until it's required and then sometimes you need to ask or read to make sure.
Well done guys.
Wire Antenna
- Stronty
Re: Wire Antenna
plant potatoes before you lay chicken wire you will have ready cut chips. cheers j
not the chip on the shoulder type,
