Yaesu 817 IF tap mod for panadapter?
sickboy
Post by sickboy » 11 Feb 2018, 20:53
I don't know why but I fancy having a panadapter display for my 817.
I've read about it on a few different blogs, and some say to put put the IF signal through a small buffer board like this one https://www.ebay.co.uk/itm/DC-12V-10KHz ... 1438.l2649, but then others are saying just to tap it using a 100pf ceramic cap and a 150 ohm resistor in series. The idea being that you then connect the 68MHz signal to an SDR dongle to use as a cheap 'n' cheerful panadapter.
Has anyone here ever tried this that can offer any advice? Is the buffer board necessary?
https://ve3ips.wordpress.com/2016/08/12 ... -6833-mhz/
http://www.geekshed.co.uk/yaesu-ft-817-if-tap-for-sdr/
Embrace your inner muppet !
Kaos
Re: Yaesu 817 IF tap mod for panadapter?
Post by Kaos » 12 Feb 2018, 19:51
I have tried it on my 857 and was just pure overload.....So yes Buffer board would be recommended
I use my FT950 and the panadapter direct to the output IF for the DMU. With the tuner on the 40m long Di-pole its great.
sickboy
Post by sickboy » 12 Feb 2018, 20:50
Thanks for that. I'll order the buffer board, but knowing me, by the time it comes from China I'll have a different radio :)
KlondikeMike
Call Sign: 9WR2000
Post by KlondikeMike » 13 Feb 2018, 00:56
I ordered a couple of these just before Christmas and they just recently arrived. I had a similar project in mind. The construction and quality look pretty good with the caveat that I have not tested them yet and they are from China.
9WR2000
