ground problem ?
nordhavn
ground problem ?
Post by nordhavn »
I've got a yaesu 897 with about 30m of wire ran through a 9:1 balun . Swr is great on 20m and a couple of other bands (don't need a tuner) I decided to earth the radio and the balun but the swr went sky high , so high the fc30 wouldn't tune it .... is there any reason for this ?
Cheers
Re: ground problem ?
Post by ch25 »
Garbage antenna, so the results.
Tigersaw
Call Sign: GW6RRL
Post by Tigersaw »
Earth to what? Best to unearth the radio, run a counterpoise from the 9:1 cold side.
And its not a bad antenna, I've worked good 80m with the same
nordhavn
Post by nordhavn »
Tigersaw wrote:Earth to what? Best to unearth the radio, run a counterpoise from the 9:1 cold side.
I did just that , all good now thanks .
