Can anyone ID this for me please?
The bottom ground planes are my addition (I assume it had some originally).
The length from the bottom to the spiral coil is about 1m but longer than that above... Ihave it tuned to an SWR 1:1 on 145MHz at 50ohms.
2m antenna identity
- Sam P
- Call Sign: 26DR340
2m antenna identity
Ubique Loquimur
- Auldgeek
- Call Sign: GM0BRJ
Re: 2m antenna identity
It looks similar to a Ringo Ranger although it's slightly different.
Where at the antenna is the coax feed?
Auldgeek - Drew
- Sam P
It's fed straight up the bottom ---- Oooerkilimax wrote:It looks similar to a Ringo Ranger although it's slightly different.
I assume the top element is 5/8 or 3/4 for 2m????
Ubique Loquimur
- Auldgeek
- Call Sign: GM0BRJ
The Ringo appears to be fed mid point so end fed rules that out. The phasing coil mid way up suggests perhaps a double 5/8
Certainly familiar looking but haven't found anything in the short look I've had on the usual websites.
Auldgeek - Drew
- Sam P
kilimax wrote:The Ringo appears to be fed mid point so end fed rules that out. The phasing coil mid way up suggests perhaps a double 5/8
Well thanks for having a go... it certainly seems to work well but my analyser doesn't cover UHF so I'm a bit stumped on that side of thing.
Ubique Loquimur
