End fed
TimH1971
Call Sign: 26CT2116
End fed
Post by TimH1971 »
Hi all
Looking to install my end fed antenna and wish to out the feed box on a tv aerial pole which currently holds a to aerial.
My query is will the tv aerial coax which runs down the pole cause interference with the feed box or indeed the tv antenna itself which will be about 4 feet above the feed box?
Tim
ghost123uk
Call Sign: 26TM953
Re: End fed
Post by ghost123uk »
Need more info about what this end fed antenna is and what it to be used for.
Also, is the "feed box" using balanced (300 Ohm) feeder, or coax?
dt630
Call Sign: 26dt630
Re: End fed
Post by dt630 »
Sound like TVI in the making.
Midget
Midget
“Light travels faster than sound. This is why some people appear bright until you hear them speak.”
WWG1WGA
Tigersaw
Call Sign: GW6RRL
Re: End fed
Post by Tigersaw »
If its a cheap and nasty one using iron powder cores then you probably will cause yourself TV interference yes. Also remember that end feds are high voltage, so be careful to keep the box and cable away from direct contact with anything.
