Iv Been Off The Radio For A While After Moving Into A 3rd Floor Flat (council wouldnt let me put up a Antenna)
Now Iv Moved Into A Bungalow , So Its Time To Get A Radio Again
But I HAve A Problem
Im Thinking Of Getting A Diamond X50 Or Sharmans X50 ......Would There Be That Much Difference Between The Two ? ?
Also The Only High Place I Can Put it Is On A 7ft Pole On The Gable End
The Problems Is .I Have A Tree Right Next To Me And The Antenna Will Be Right In It
It's Ok Now I Suppose But When Spring Comes It Won't Be Visable Due To The Leaves
What I Want to Ask Is ... If I Dont Put It There , The Next Best Place Is On My Guttering
Which Will Be 10ft Lower But About 15ft Away From the Tree
Which Would You think Would Give Me The Better All Round Performance
