which coax 213 rg8 mini x
hi guys I am setting my new antenna up on the gable end of a 3 story flat I am on the top it will be on a 10ft pole antenna I will be using is the x30 as I have just been giving permission I used to use rg8x but I was thinking of getting rg213 I used to use rg8x mini at my parents house as I could not have anything thicker really would there be much difference in loss between 213 and rg8x mini as only using a 13 meter run thanks guys
- Auldgeek
- Call Sign: GM0BRJ
Re: which coax 213 rg8 mini x
Auldgeek - Drew
- LeakyFeeder
213 if you can... Only ever used RG213/u or as i do now Heliax 450.... Feeder isnt summat you can ever skimp on... Even me Shakie i have for 11m has good 213 shoved into it
