i put up a home made inverted v antenna using thin stainless steel wire i had..for the 40 meter band..... the atu on the radio , yeasu FT450AT got the swr down a litle more and i got some great contacts on it... last night my mate came round with his swr meter and checked how low it actually was ... it was high ... over 2.5 ... we tried to adjust the swr by moving the ends in 2 inches at a time , but after over 2 foot later we put it back to the origional position and lengthened it 2 inches at a time up to 2 foot ... no difference whatsoever ...
we called it a night and decided to changre the wires for multi stranded, plastic coated ..... this morning i took the antenna down and measured the lengths out to 35 foot exactly each side ( start long and work in .....)
6 hours later... after shortening the ends 3 inches at a time ... STILL the swr's well over 2 even tho we shortened it right back to 32 foot
took it down , re soldered and checked all connections twice and the thing just wont drop on the the swr .......
i can receive brilliantly on it ( and 40 was banging all day here today ... typical ahhh )
anyone any ideas on what the hecks going on with it ??
thanks
totally baffled ...help needed please
- NITRO
163-TM-565
- Tigersaw
- Call Sign: GW6RRL
Re: totally baffled ...help needed please
When your antenna is resonant it doesn't mean its matched to 50 ohms. In fact a low swr isn't always an indication of a good antenna. You need to put an analyser on it to see whats going on.
If you really need to see a low VSWR, then try a 1:1 balun at the feed point, insert a common mode choke at a convenient place, try altering just one leg a bit at a time in case of imbalance etc.
- Call Sign: 121
Vswr at 2 is not bad the fact the ATU tunes it you worked on it and it receives fine I'd leave it.
- kr0ne
And if you're absolutely determined to lower the SWR measured at the back of your radio, lenthening the coax by 30 metres or so is probably the easiest way...
(There is a real point behind the above statement, if you can see through the facetious sarcasm...)
- Unit 148 Mobile
- Call Sign: G4ZOW
1. Tune the antenna to resonance.
2. Use the ATU to match it's impedance to 50 ohms.
Unit 148 Mobile.
Unit 148 Mobile.
