Hi all I'm looking at buying a 12m telescopic antenna mast either from Tennamast or from lnnovantennas this is the one I'm thinking of
http://www.innovantennas.com/antennas-a ... id/63.html
any advice would be appreciated I'm not sure whether to go with tennamast or Innovantennas mast are any of you using these masts and if so what is your opinion of them any information would be appreciated thanks
Telescopic Mast
Re: Telescopic Mast
The Tennamast is probably the better made of the two (being 90mm box section), but the other one is pretty well-made too but is 80mm box, so it really depends on what you intend putting on top of it.
You are aware that the mast being offered by Innovantennas is actually made by MM0CUG, and can be bought directly from him cheaper. He will deliver it free of charge, and he also offers an installation service, I believe. He has a website with all the info.
http://www.mm0cug.co.uk/
Re: Telescopic Mast
Looked at this again this evening and noticed that the Innovantenna deal includes a free rotator cage (must have missed that earlier), so that might be something to consider if you are leaning towards that mast.
Re: Telescopic Mast
Thanks for the information much appreciated 73's
