I've acquired a Kenpro KR-400RC antenna rotator and control unit. It all seems in good order, though there's a slight crack in one of the clamps for the rotator itself.
I can get the crack sorted east enough, but does anyone have a wiring diagram or instructions for the wiring between controller and motor? Or indeed, any other advice or useful info?
I'm not sure what to do with It yet, but before I either use it or sell it I want to refurbish it and check it functions properly.
Cheers,
Farty.
Antenna Rotator
- Farty
Antenna Rotator
Re: Antenna Rotator
round controller ?? square controller
the terminals are numbered 1 to 6 so wire 1 to 1 etc
for the round controller you dont connect no1
wire it 2 to 2 etc
wire it 2 to 2 etc
Dont worry what class of licence he holds, worry what class of bias he applies to the amplifier !
- Farty
Re: Antenna Rotator
Big square controller. Cheers matey, that makes it easy!
Gonna replace the cracked clamp, cleaning all up, regrease and repaint and decide what to Do with it.
- Call Sign: RDX64
- Farty
Re: Antenna Rotator
Cheers Matty! I really should have checked the obvious...
- Call Sign: RDX64
Re: Antenna Rotator
lmgtfy4u lol
