Hi Guys.
Did any one of you tried to use this software and what kind of results did you get, looks very interesting.
There is also video on the Youtube from 9V1TD/W8TOD with really impressive results.
http://www.dxatlas.com/VShaper/
Thank you.
Voice Shaper
- Call Sign: 26TM142
Voice Shaper
26TM142 ADAM
Kenwood TS-870, Sirio Gain Master,G5RV half dipole, Beyer Dynamic TGV35 Microphone, Allen and Heath IDr4.
Listening on 27.555 USB.
- Call Sign: RDX64
Re: Voice Shaper
Now that you have had a chance to try it yourself - have you ?
Was it any good?
Do tell.....
Was it any good?
Do tell.....
- mr_h4ck3rm4n
- Call Sign: MM6SGZ
Re: Voice Shaper
I've used this with a usb condenser microphone into the pc and the audio out going into the radio... Worked well but was abandoned as the mic picked up rf ... But it did work well,
However I did try running an audio cable from the radio to the computer and monitor the audio from standard base mic while using the radios monitor function, this let me see the effects that the radio DSP and EQ has on the TX audio using the scope display as a visual.... However there are lots of other audio scopes out there...
HF
Ameritron 811, Yeasu FL2100
VHF/UHF
Icom IC-208H, Icom IC-2820
Jotron TR7550 VHF Air
Antenna
Data Interface
QRZ.COM
