RG58 or RG213
eswnl
RG58 or RG213
Post by eswnl »
Hi,
Having decided to put a g5rv outside and running about 15m of coax, I was wondering if RG58 would suffice, being at low frequencies/easier to manage. The coax would be coming out of the eaves and drape across to the g5rv feedpoint. I guess RG58 is lighter than RG213 and so would not put too much strain on the antenna.
northern35s
Re: RG58 or RG213
Post by northern35s »
Without doing a little research I don't know what the losses are in 15m of RG58, but at HF frequencies they are minimal. I feed all my antennas at home with RG213, mainly because I can and would like to reduce the loss, however for the length of run I have I doubt I'd notice the difference between RG213 and RG58. It's a different story at VHF and UHF, where RG213 becomes a bit too lossy.
MrWeetabix
Admin
Admin
Call Sign: 26TM175
Re: RG58 or RG213
Post by MrWeetabix »
213 is regarded as better than 58, though at HF, you'll not notice the difference. If you can afford 213, then go for that, a much better buy and can be re-used for VHF/UHF at a later date. :mrgreen:
Jon_D
Call Sign: G4FUT
Re: RG58 or RG213
Post by Jon_D »
The coax would be coming out of the eaves and drape across to the G5rv feedpoint.
Then if this is fed with coax, it is not a G5RV. That antenna is fed with open wire feeder at the feedpoint and the only coax is that which comes from the TX which is THEN attached to the open wire feed; the latter is generally 300 Ohm.
Are you taking about a dipole fed with the coax?
eswnl
Re: RG58 or RG213
Post by eswnl »
Sorry, I meant to say that the coax plugs into the ladderline that hangs from the middle of the antenna.
Jon_D
Call Sign: G4FUT
Re: RG58 or RG213
Post by Jon_D »
Thanks for that...I didn't mean to be contentious. I was about to advise on velocity factor and ATUs. but needn't now. :D
Good luck with the G4RV; If you get it on 6 Metres, let us know as i need an antenna for that band.
Even if the voices on my head aren't real, they do have some pretty good ideas
Jon G4FUT
Ex-Army
RSARS 1425
g0slq
Re: RG58 or RG213
Post by g0slq »
MrWeetabix wrote:213 is regarded as better than 58, though at HF, you'll not notice the difference. If you can afford 213, then go for that, a much better buy and can be re-used for VHF/UHF at a later date. :mrgreen:
There used to be a (rough) guide.
RG58 HF
RG213 VHF i.e. 6/4/2m
Westflex 103 UHF
SUHF, i.e. 23cm and up Ecoflex 15 - with an eye-watering cost of £5+ per meter to keep losses to a miimum!
G0SLQ website
Icom IC-7100 + two patchleads and a broken PL
Captain Lockheed
Re: RG58 or RG213
Post by Captain Lockheed »
eswnl wrote:Hi,
Yep, RG-58 is considerably lighter, so if that's a major issue then go for it.
Just don't go shoving a kilowatt of rtty up it on 10m, RG-58 doesn't like that... apparantly :D
Yeti
Re: RG58 or RG213
Post by Yeti »
RG58 HF
Westflex 103 UHF
You forgot LDF450 :P
g0slq
Re: RG58 or RG213
Post by g0slq »
Ahem
Not forgetting LDF 450 of course for those whacky enough to transmit 2.4Ghz and higher ;)
G0SLQ website
eswnl
Re: RG58 or RG213
Post by eswnl »
Thanks for the replies. I managed to find a website that calculates line losses, so I've decided on the rg58.
So coax has power ratings? Too much power would cause the coax to melt?
Captain Lockheed
Re: RG58 or RG213
eswnl wrote:Thanks for the replies. I managed to find a website that calculates line losses, so I've decided on the rg58.
Said mainly in jest, but yes, all transmission lines have a limit but they are not really relevant to anyone using U.K. limits on HF. With RG-58 it's not an issue until using silly levels of power on higher bands and using 100% duty cycles modes, i.e. 10m and rtty.
Yeti
Re: RG58 or RG213
Post by Yeti »
Yes.
MrWeetabix
Admin
Admin
Call Sign: 26TM175
Re: RG58 or RG213
sizzle sizzle
YB135
Re: RG58 or RG213
Post by YB135 »
May I draw your attention to this link: http://news.bbc.co.uk/1/hi/sci/tech/8661228.stm
I think this picture was taken when wor bixy' downed the key on his new 10kW burner with very poor coax connected, as you can see from the previous picture that is what happened to the coax. Note on http://news.bbc.co.uk/1/hi/sci/tech/8661228.stm the strong reading from the north east of england, maybe the newcastle region... hmmmm coincidence????
YB135
