Pye Westminster modern guts
Hi just bought a retro pye westminster for my 74 land rover because I like old stuff any one seen one with modern innards or can I use a PLL to vary the freqencies as it only has 4 channels at present any help would be greatly appreciated cheers Nick m1bto
- Andy
Re: Pye Westminster modern guts
Hello - are you the one who has asked a similar question over on the Vintage Radio site?
There was an article many moons ago in Radcom, describing a PLL synthesizer for a Westminster, but it was very complex due to the different RX/TX multiplications used in the radio.
I'd stick to the crystals if I were you - you probably only need the calling channel plus a couple of QSY freq's, so the cost of the xtals will come to less than the cost of the various bits (and the deep, deep heat-ache) of the conversion.
I ran an FM Wessie (mobile and fixed) on 4m for years, and they're a fine rig without any mods. You've just got to make sure you follow the tune-up procedure (all those multipliers...) to the letter or you can end up talking to your local taxi firm!
'SOMEONE GET ME A SAW!'
Andy.
Andy.
- RogerD
I'd rip out the old guts and put a cheap Puxing/Wouxun inside it
Hi yes I did post on the other forum they did rather **** on my chips sacrilige ? I will have a look when it arrives could I feed the pa with milliwatts and just the amp and put in a puxing or similar don't tell the other forum they will lynch me
