847 hidden menu to make the receive more sensitive
- wheel bender
I out worked my friend's yaesu with a delta force on fm mode. He wants to know if he can open up the receive a bit to hear the weaker stations, any help will be usefull.
Wheel Bender 1982-88/ 2007- ???
27+ countries since 2007
keeping the older radios on air. Not in the cupboard or the past.
80ch legal- America on ukfm- CB radio can be better 2nd time around.
- darkone
Re: 847 hidden menu to make the receive more sensitive
Any service menu settings that increase RX gain will also increase the noise level.
Did you test them side by side on the same antenna?
- MrWeetabix
- Admin
- Call Sign: 26TM175
Personally, I'd be wary of chaning service menu settings. an 847 would make for a pretty expensive paperweight!
- northern35s
[quote="darkone"]Any service menu settings that increase RX gain will also increase the noise level.
Did you test them side by side on the same antenna?[/quote]
That's the important bit, a chap local to me works hf pedesrian mobile and he can be 1/2 a mile away talking states side and can barely hear who he's talking to (ok so my antenna's crap )
Side by side, and using the same antenna.
I also suggest your friend buys himself a bhi nes dsp speaker, massive difference on receive, much better than the built in DSP on the FT847.
- Yeti
1) The 847's recieve on HF isn't that great - it's primarily a VHF/UHF multimode.
2) Anything you change in the menu to increase the gain will increase the noise also.
3) Anything you change in the menu to increase the S-meter reading will not necessarily increase the actual signal.
4) The 847 will make an expensive paperweight.
5) In case you missed the point of the other points above - leave it alone!
- wheel bender
We wern't running on the same aerial. Thanks for all your replies. I'll pass them on to him. He tried altering the secret menu and as you say only increased the noise level. I know exactly what you mean about it not handling 27mhz like some other radios dedicated to those frequencies can. Thanks again for your replies. He's waiting for a Delta force to arrive.....Lol!
- Yeti
I'm willing to bet an 847 will outperform a Delta Force on 11m.
- Silent Key
I'll have a pound on that too my moneys on the 847, and that's after owning both at some stage
MW0TMI / 2W0XTP / MW6VHF
Yaesu Ft-920, Yaesu MD-200 , Trap Dipole, 150ft End-Fed and 3Ele 6m Beam, Western HF Dipole.
Kenwood G707 Dual Band VHF TM163010
*Message from Admin - Dean Sadly passed away in May 2012. R.I.P. Dean.
- Banned
But, Yeti, many people in here think that a higher S-meter reading means it receives better...Yeti wrote: 3) Anything you change in the menu to increase the S-meter reading will not necessarily increase the actual signal.
[/quote]5) In case you missed the point of the other points above - leave it alone!
You're posting in the wrong place
- Banned
Oh FFS....wheel bender wrote:We wern't running on the same aerial. Thanks for all your replies. I'll pass them on to him. He tried altering the secret menu and as you say only increased the noise level. I know exactly what you mean about it not handling 27mhz like some other radios dedicated to those frequencies can. Thanks again for your replies. He's waiting for a Delta force to arrive.....Lol!
There probably is nothing wrong with his Yaesu and everything wrong with his antenna. You cannot claim to have "out performed" his Yaesu unless you were on the same antenna.
Congratulations on probably getting him to waste £200+ to see no improvement.
- Banned
Mine too. Wheel Benders comparison was not a true one because his antenna is probably working far better.dean_aberdare wrote:I'll have a pound on that too my moneys on the 847, and that's after owning both at some stage
I have two antennas here. The CP6 on 20m is 6dB down on the 20m dipole depending on location of the other station. On stations in Russia, the dipole will sometimes hear stations that are completely unheard on the CP6 and vice versa if there are stations to the south.
So unless he went round to his mates house, unplugged the 847 and plugged in the Delta Force, then its not a fair comparison.
I reckon there's £200+ just about to be thrown away.
