IC7100 - USB Cable
radiogaga
Call Sign: 26TM399
IC7100 - USB Cable
Post by radiogaga »
Anyone know if the Mini-USB cable supplied with the 7100 is a generic USB cable?
Can't for the life of me get my 7100 to connect to the PC, left the original cable in the UK!
30TM399 Northern Costa Blanca
Re: IC7100 - USB Cable
Post by ch25 »
Any USB cable with proper plugs will work.
radiogaga
Call Sign: 26TM399
Post by radiogaga »
Emmmm.. Thanks - Stumped now!
Auldgeek
Call Sign: GM0BRJ
Post by Auldgeek »
radiogaga wrote: 11 Aug 2018, 18:25 Anyone know if the Mini-USB cable supplied with the 7100 is a generic USB cable?
A standard USB cable will work but I believe you need to install a driver on the PC to allow the two to communicate.
Check out the Icom website for more info.
radiogaga
Call Sign: 26TM399
Post by radiogaga »
Yep, it’s the same laptop from the UK so I know it’s not driver related.
It connects to the CS7100 software just not data modes... Never used the data modes on this laptop though. WJST-X
Auldgeek
Call Sign: GM0BRJ
Post by Auldgeek »
radiogaga wrote: 11 Aug 2018, 20:04 Yep, it’s the same laptop from the UK so I know it’s not driver related.
This might help
https://www.aa0no.com/digital_modes_setup_ic-7100.htm
radiogaga
Call Sign: 26TM399
Post by radiogaga »
Thanks. No difference, those instructions are pinched from someone from QRZ Forum.
It’s frustrating.
I have noticed that the radio has added two ports in device manager which is odd.
Auldgeek
Call Sign: GM0BRJ
Post by Auldgeek »
radiogaga wrote: 11 Aug 2018, 20:44 Thanks. No difference, those instructions are pinched from someone from QRZ Forum.
It’s frustrating.
I think that's as it should be, as there are 2 virtual ports. I've got rid of my 7100 a while ago, but can remember there being 2 ports. I think this is due to the multi-function capability of the port, such as 1 for rig control and one for the builtin soundcard.
Anyway, hope you get it working. I'm sure you have already done this, but there's quite a bit of info on the web about this
**Edit**
Found this about the 2 USB ports.
http://radioaficion.com/cms/icom-tips-f ... -settings/
radiogaga
Call Sign: 26TM399
Post by radiogaga »
Magic, thanks, I’ll take a look later today.
