mounting brackets
A place to discuss the amateur radio licence, training and examination.
stanogs68
mounting brackets
Post by stanogs68 » 19 Apr 2017, 21:57
what mounting brackets do you suggest to come off the wall and miss the gutter on the back of the house ,i know theres T brackets but there dear i think and the aerial isnt that heavy ,any ideas thanks
bc73
Re: mounting brackets
Post by bc73 » 20 Apr 2017, 06:40
I have the same issue and had to get some extra long t&K brackets but they were very easy to obtain. Fitted them myself using chemical anchors and so far have been good.
Hope this helps
Col
_____________________________________
MM6BCF
108 TM 45
FT-747-GX.
IC-706-MK2G
Yaesu FT7
Stalker 9FDX
Dirland SS3900E
Nato 2000
Alinco DR135
Amstrad 901
73 and 51
Nothing's ever easy! {bnghd}
Tim
Call Sign: 26AT239
Post by Tim » 20 Apr 2017, 12:23
There will be a cost what ever you use. You can very easily make brackets yourself with sections of angle iron and a welder.
stanogs68
Post by stanogs68 » 20 Apr 2017, 14:41
i was thinking that there easy to make really arnt they ,there like £18 for big t+k brackets my mates has a fabrication shop but i just dint want to be a pest as hes busy and i havnt got a welder know more ! i was thinking is there any other type of bracket i could use ?? i cant put it on the chimney as my antrons there !
nay27uk
Post by nay27uk » 22 Apr 2017, 12:20
Just a thought but what about a Satellite dish mount? They should stand out far enough to clear the eaves and even have a tube/pole mount built in as the actual dish is mounted to the bracket on a bent pole.
Something like THIS mate, you can get longer ones than that though.
If it don't come out far enough to clear the eaves, cut a thick piece of wood a little larger than the dimensions of the mounting points in the bracket, screw the wood to the wall, weather protect it then screw the mount to the wood.
Just an idea of the top of my head stan.
Or if you get a long enough ally mounting pole you could get someone with a pipe bender to put you an Z or S shaped bend in the mounting end so the pole looks something like the picture.
M6LIG / 2E0LIG / 26TM1995
Realistic Pro 2006
Panasonic DR28-LBE
Baofeng UV5R+
YAESU FT-857D
nay27uk
Post by nay27uk » 27 Apr 2017, 16:15
Was my above post helpful stan?
Realistic Pro 2006
Panasonic DR28-LBE
Baofeng UV5R+
YAESU FT-857D
