Sorry but you have been taught wrong. It would be good if you could let your trainer know that they are giving instruction that is different to what the licence recommends. You should use /A if you are at a location that has a postal address. It's not a licence requirement but it's good practice to use the guidance within the licence.owza wrote:
As for the portable/mobile. We have simply been taught that if where you are transmitting from has a postcode then use /p.
The licence document tells you most things you need to know:
(d) When operating at locations other than the Main Station Address, it is recommended that
the following suffixes be used:
I. If the Licensee operates the Radio Equipment at an Alternative Address, the Licensee may use the suffix “/A” with the Callsign;
II. If the Licensee operates the Radio Equipment at a Temporary Location, the Licensee may use the suffix “/P” with the Callsign;
III. If the Licensee operates the Radio Equipment from a Mobile location, the Licensee may use the suffix “/M” with the Callsign;
IV. If the Licensee operates the Radio Equipment from a Maritime Mobile location, the Licensee may use the suffix “/MM” with the Callsign.
(jj) “Temporary Location” means a fixed location in the United Kingdom which is not
the Main Station Address or an Alternative Address;
(x) “Mobile” means the Radio Equipment is located in the United Kingdom:
I. in or on any vehicle or conveyance;
II. on the person of the Licensee where the Licensee is a pedestrian; or
III. on any Vessel on Inland Waters;
This is how I remember and use it:(u) “Main Station Address” means the main station address stated in Section 1 of this Licence;
(v) “Maritime Mobile” means the Radio Equipment is located on any Vessel at Sea;
/M - Mobile (I can move the station whilst operating with no modifications, for example, a hand held, or a car with antenna on roof)
/A - Alternative (I am at a station that has a postcode but is not my main station address and not /M, for example, someone else's station or a station set up at a holiday rental apartment)
/P Portable (I am at a station that does not have a postcode and not /M, for example, a field or a car with an antenna thrown in some trees)
/MM Maritime Mobile (I am a station on a boat operating in tidal waters)
