Indoor antenna
A place for new members to say hello and to introduce yourself.
If you're not sure where to post, try here!
Archie
Call Sign: 108PD459
Indoor antenna
Post by Archie »
Hi my name is Archie from Scotland I am going to ask you what is the best antenna to use indoor and a ground flat for a CB
Call Sign: G4RMT
Re: Indoor antenna
Post by paulears »
Indoors, sadly means you won't be talking to people from very far away, and of course, you'll probably annoy anyone watching TV, or using computers, because everyone will be close to the antenna. Probably the simplest is a simple wire dipole - 2.7m ish from the coax centre one way, and the same from the braid the other. if you can't get a dipole up, which with a bit of electrical choc-block is simple to make, because the room is too small, you can bend the ends at right angles a bit to make it fit. You say ground floor - do you have a garden that a bit of wire would go unnoticed?
The facts though are that if you did the old fashioned thing and stuck a car antenna on a metal plate of some kind, you can get out - a bit. With all radio systems the antenna really is the thing that does the work, rather than the power. Indoors, everything works against you.
Question
Do you need to talk to specific people using CB, or do you just want to chat? If it's just chin wagging, try network radio on your phone - zello and similar software. You can chat all over the world for free.
MrWeetabix
Admin
Admin
Call Sign: 26TM175
Re: Indoor antenna
Post by MrWeetabix »
Do you have access to a garden at all? The Wire-dipole (as described by my Zello-loving Friend above) would work much better outside.
Perhaps you could give us more of an idea what you have access to externally so that we may have suggest a method of getting on the radio with some other kind of antenna or mounting idea....
jamie006
Re: Indoor antenna
Post by jamie006 »
Hi Archie. Ive just been experimenting with an inverted vee wire antenna in the loft. Im afraid i didn't have much success with it as the reception wasn't up to much. Outside is really the best bet if possible. Even a mobile antenna on a bracket would work.
108EH002
Re: Indoor antenna
Post by 108EH002 »
Hi Archie,as suggested above you will be very restricted with indoor antennas,but a loop at the window/small mobile whip on a small metal plate geound to your copper pipe on the radiator helps lower the swr and increase the performance slightly.
Archie is a new local breaker who has been pushed in the right direction,he has an Imax outside now and a wee homebrew dipole horizontal 8 ft up along a wooden fence 👍
27.555 Usb
MrWeetabix
Admin
Admin
Call Sign: 26TM175
Re: Indoor antenna
Sounds like he's on the right path now. Hope it's all working out for you Archie. Welcome to TM1 and welcome to the world of Radio
Archie
Call Sign: 108PD459
Re: Indoor antenna
Post by Archie »
Thank all of yous very match yes some good advice has been given. I have an i max now and doing the job one of my friend showed me how to make a dipole as well all is working great 🐺
MrWeetabix
Admin
Admin
Call Sign: 26TM175
Re: Indoor antenna
Great to hear Archie. Glad you have some good local breakers to help you out aswell.
Best 73 de Craig
as1mov
New User
New User
Re: Indoor antenna
Post by as1mov »
Hello Archie,
There's a good vid on YT on how to make a very reliable T2LT dipole suitable for 11 and 10mtrs. entitled Very cheap and easy to make portable CB Ham antenna, well worth a watch.
Tommy
(108CT219)
NightProwler
Call Sign: 163TM186
Re: Indoor antenna
Post by NightProwler »
Zello? Zello? Gordon Bennett :roll:
