Hi all
Im new to all this so id appreiate any help and advice. Im looking to get a scanner as a hobby and wondered which one is best to get. And what aeriel do i need for top of roof. id like to get something that goes miles out from where i live and can pick up everything there is to pick up. Do different aerials pick up different stuff not sure how it works.
thanks alot
Hi from South Yorkshire
Re: Hi from South Yorkshire
Hi (ho) silver, welcome to TM1, nip across to the scanning section and have a read of old posts about what scanners people like and don't like.
- andymuza
Welcome aboard, you are sure to get the info you need in the Scanning Section.
- MrWeetabix
- Admin
- Call Sign: 26TM175
Welcome to TM1. I hope you found the info you needed!
