Hi Keith
Welcome to the forum, you have more luck posting this question in the scanning section but there is an 'easier' to read manual available for this radio that may help you:
http://marksscanners.com/230/230.shtml
Uniden USC230-E Scanner
- alannah
- pbell283
- Banned
Re: Uniden USC230-E Scanner
Thanks, Phil
(69-tm-220)
Icom ic-706 mk2
Icom Ic-211e
Philips FM1000 2m converted radio
Stalker 9 cb radio
Bearcat 15x scanner
Realistic pro-41 scanner
g5rv antenna
sirio SA270MN for 2m and 70cm
Antron cb antenna
(69-tm-220)
Icom ic-706 mk2
Icom Ic-211e
Stalker 9 cb radio
Bearcat 15x scanner
g5rv antenna
Antron cb antenna
