hello im new to scanning so this is probably a simple question but here goes
i recently set this radio up and as im about 4miles from east midlands airport i though id try to receive some signals from there i cant receive anything clearly from there despite having line of site could this be the ariel im using the one supplied small telescopic ive also heard that the control software supplied isnt very good any ideas would be appreciated as its really frustrating not to be able to hear anything
thanx
icom pcr1000
- Andy
Hi Kris. If you are four miles away through dense urban landscape, then you probably wont get very strong signals on a little telescopic antenna. The ground services on UHF are only designed to cover a small area, and comms to the aircraft tend to have a clear line-of-sight so they don't use a lot of power. A discone or similar on your chimney will make a vast difference.
'SOMEONE GET ME A SAW!'
Andy.
Andy.
A better quality antenna will help. I was talking to someone at the radio club the other night & he uses a decent quality (& longer) rubber duck & it adds a couple of s points to each signal.
He is an electronics engineer & a G3, been around years seen it all, done it all & always willing to talk.....Scanning his biggest love.
I normally just use the standard duck, but I do have a telescopic that can be base, mid or top loaded, depending on which bands you are using & it does make a difference.
