Hi all
i just got my discone aerial off ebay it came with an short plastic pole that fixed to hub where to plug cable in ,my question is there any reasion why i can replace that with an longer metal or aluminum pole one i got in mind is off an old cb aerial it 32" long
so can or can't i ?
thanks for any help or advise given
Gavin
discone aerial
- Andy
Use decent coax though.
RG58 will lose too much signal, especially at UHF.
I found that I was receiving things on my handheld antenna that I was not on the discone until I upgraded the coax.
So I passed this test that allows me to twiddle with knobs, push buttons & call my self an Advanced !!!!!!!
M0LSX
M0LSX
ordered wrong cable
yeah i heard that about cable i ordered some low loss cable just waitting for the thing to come in post
EDIT i ordered normal RG58 cable not low loss AHH any way what do you think of this stuff ???? http://cgi.ebay.co.uk/RG213-50-Ohm-Low- ... dZViewItem
thanks
gavin
EDIT END
thanks
gavin
EDIT END
- Transmission1
- Admin
- Call Sign: 26TM001
RE: ordered wrong cable
RG58 is fine for HF up to 30 MHz but the stuff you are looking at on ebay is much better for UHF, the only downside is the thickness of the cable, it's not very flexible and a bit of a pain to bring into the house unless you have some air vents with large holes that you can feed it in with.
I have used a reel of this stuff before: http://www.truck-king.co.uk/xcart/custo ... =36&page=1
it's got similar properties to RG213 but It's called Mini RG8/U and it's much thinner.
Regards
Simon
Regards
Simon
Simon, 26TM001 - East Yorkshire, UK
Founder of Transmission1 & Tango Mike 26 Division Co-ordinator
http://www.tangomike.net/
Follow me on YouTube: https://www.youtube.com/@transmission1
- Andy
At the risk of scaring the horses, I've been using CT100 satellite cable on my scanner antennas for years. It's only a bit thicker than RG58, it's flexible and it has very low loss up to about 2GHz.
It's 75-ohm, but that soesn't make a jot of difference - the loss due to mismatch is only a fraction of a dB.:
RG58 : 7.6dB loss per 10m at 1000MHz
RG213: 2.6dB loss per 10m at 1000MHz
CT100: 1.8dB loss per 10m at 860Mz and 2.7cB at 1700MHz.
'SOMEONE GET ME A SAW!'
Andy.
Andy.
Re: RE: ordered wrong cable
i ordered some mini rg8/u off ebay it pain in butt to get pole up never mind aerial on top not going do more than onceTransmission1 wrote:
Regards
Simon
