Create CLP-5130-2N high gain antenna ??
oldpink
Post by oldpink » 09 Apr 2019, 19:10
been looking for a new antenna to replace my Sigma 1300 discone
I looked at the Diamond x 700 2m - 70cm as it will be used with a SDRplay RSP1a or Duo when I upgrade but its too restricted to its bands as I want to cover 137.000mhz for the Noaa satellites and 450.000 - 460.000 for DMR
the Create CLP-5130-2N seems the better option if not a bit more expensive and I think I'll mount it onto a rotator for maximum coverage
anyone here ever used one
or know of a better option ??
one of the reasons I looked at this antenna is it can be used to track meteor showers so it ties in with my astronomy
TIA for any input
I hear Radio Waves in my head
CRT SS 6900 Fully modded Export setup programmable
Cobra 148 GTL DX Mk 2
Alan 9001 26 - 30.190 multi band
SDRPlay RSP1A x2 with a Create 5310 on a rotator and Discone for general
108-TM-046
Call Sign: Lemmy
Re: Create CLP-5130-2N high gain antenna ??
Post by ch25 » 09 Apr 2019, 19:13
For NOAA I would use QFH.
For scanning I would stay with omnidirectional antenna. Too much signals missed when directional will be turned to wrong direction.
oldpink
Post by oldpink » 09 Apr 2019, 19:23
I'm looking at building a dedicated QFH or possibly a turnstile specific for Noaa but I want to cover a lot more like airband & 10m and as I said meteor stikes
so directional works best the Omi directional has no gain and I have a 20ft mast I can mount a rotator onto for £150 and put the antenna up on an ally pole another 10ft as its only 5Kg and the rotator can take up to 45kg
108-TM-046
oldpink
Post by oldpink » 09 Apr 2019, 19:50
current setup
tracking Fox - 1D on 145.800 via SDRrsp 1A and Fox telem
with the discone on a 20ft mast (not the best pic)
108-TM-046
