SDRangel
stanogs68
Re: SDRangel
Post by stanogs68 » 18 Aug 2018, 18:56
have you the place were the right app is :oops: :oops: :oops: :lol:
gmham
Call Sign: 108TM154
Re: SDRangel
Post by gmham » 18 Aug 2018, 18:59
will pm you a link mate, you still having trouble with the github download ?
in all honesty mate and I am not being funny but I think you may struggle once you get the app open its a bit off a nightmare. persoanaly would get the other TM member to teamviewer to your pc to set it up for you, I have been at it for a week or two and still struggling !
Icom IC7300 HF /6 mtrs
Kenwood TS711E 2 mtrs ssb
108-TM-154 - John
gmham
Call Sign: 108TM154
Re: SDRangel
Post by gmham » 18 Aug 2018, 19:06
PM sent mate !
" Radiogaga " get out the pub mate we need you !! :lol:
108-TM-154 - John
stanogs68
Re: SDRangel
Post by stanogs68 » 18 Aug 2018, 19:12
this sounds like a headbanger ,your right mate get someone with team viewer who has a bleeding clue :D :?: :?:
gmham
Call Sign: 108TM154
Re: SDRangel
Post by gmham » 18 Aug 2018, 19:32
Yep mate as I say personally would wait as if your like me you will just frustrate yourself and end up forgetting it all trust me !
108-TM-154 - John
radiogaga
Call Sign: 26TM399
Re: SDRangel
Post by radiogaga » 18 Aug 2018, 21:58
Hi... are you about tomorrow and do you have teamviewer or AnyDesk (latter preferred) could help tomorrow morning if you like.... wish it was the pub!
30TM399 Northern Costa Blanca
gmham
Call Sign: 108TM154
Re: SDRangel
Post by gmham » 18 Aug 2018, 22:06
Not sure if it's me or stanogs68 mate ? but if poss could I maybe take you up on your kind TeamViewer offer to set up the dmr side off things for me ? . As I say have the programme installed and working just need a hand to configure the settings to decode dmr. No probs to waitt as appreciate the other chap was the one asking for assistance first !!
108-TM-154 - John
radiogaga
Call Sign: 26TM399
Re: SDRangel
Post by radiogaga » 18 Aug 2018, 22:14
No worries. I’m in Spain so internet can be a bit iffy but I’ll give you a shout tomorrow 👍
AnyDesk seems more stable for me too, rather than TeamViewer.
gmham
Call Sign: 108TM154
Re: SDRangel
Post by gmham » 18 Aug 2018, 22:18
Okay no worries mate easy enough to download and use ie Do I have to set up anything this end or just give you my access details for you to connect it ? Will await your pm tomorrow. Thanks again appreciate that.
108-TM-154 - John
radiogaga
Call Sign: 26TM399
Re: SDRangel
Post by radiogaga » 19 Aug 2018, 08:44
No, just give me the code later. I have to do the chores first as set by the missis.
Just a couple of things you can try first which could be easy wins.
1. Make sure you are using a USB 2 port. USB3 don't work!
2. Make sure you are seeing your dongle as a device. I guess broadcast WFM is fine in SDRAngel AND SDRsharp? Not all dongles are supported.
3. I think it's only simplex that you'll be able to receive. Unfortunately I can run it up and use it but even with some great lift it isn't going to hop 1000km to me here. I don't think trunked is supported.
From 17 minutes in the youtube link is worth a look
Catch you later
gmham
Call Sign: 108TM154
Re: SDRangel
Post by gmham » 19 Aug 2018, 08:57
Good morning to you and thanks for your reply. No as I say have everything working on sdrangel ie receiving fm broadcast / fm narrow band. Am etc etc it's just getting the thing to decode some dmr. Just a bit stuck with all the settings that's what I am saying you managed to decode dmr with it yourself ?
108-TM-154 - John
radiogaga
Call Sign: 26TM399
Re: SDRangel
Post by radiogaga » 19 Aug 2018, 11:36
Yes, decoded simplex fine in the UK with Linux. I'm in Spain at the moment so therefore can do no more than install and test as I do not have my DMR handie with me. Drop me a PM when you are available on AnyDesk and include the code and we'll take a look.
stanogs68
Re: SDRangel
Post by stanogs68 » 19 Aug 2018, 11:58
did you get it done graham ? i give up went and watched telly :D
gmham
Call Sign: 108TM154
Re: SDRangel
Post by gmham » 19 Aug 2018, 12:32
No sorry mate got told off from the wife that I was hidden away in that room again !
Radiogaga - okay mate yep will pm you now. the local shopwatch freq is on 453.150 so if you could just set everything up for me for dmr decoding then that would be great. not sure if I have my input / output is correct within the audio settings off sdrangel as showing vb audio for input that was from running sdr#/ the sound is comming out okay from fm broadcast etc so guess the sound output being my speakers is correct ? if you could take a look at these settings.. appreciatte taht.
108-TM-154 - John
radiogaga
Call Sign: 26TM399
Re: SDRangel
Post by radiogaga » 19 Aug 2018, 13:56
Waiting on your acceptance of the AnyDesk. I suspect it will be trunked??
