Taking handheld scanner on a flight (Edinburgh - London
elliotg
Post by elliotg » 16 Jun 2018, 18:02
Hi
I was wondering if anyone has taken a scanner with them on a flight? I will have the scanner in my bag at all times with antenna and batteries off the radio. Will this cause problems going through security?
Many thanks
Elliot
Realistic PRO-2006
radiogaga
Call Sign: 26TM399
Re: Taking handheld scanner on a flight (Edinburgh - London
Post by radiogaga » 16 Jun 2018, 19:03
Can’t imagine so. I take my 897 with batteries to and fro from Spain. Just have to sent it separately like my laptop. I do get picked out quite often but happy with that, those guys have a tough job, some travellers just don’t get it!
30TM399 Northern Costa Blanca
scottyboy
Post by scottyboy » 16 Jun 2018, 21:08
I’ve took handheld radios on several flights, Europe and America and always in my hand luggage bag, never been questioned on it.
I would keep batteries in it and tuned to a ham frequency should you get asked about it.
Also if you have a ham license keep a copy of it in your bag.
Just helps should you get questioned.
2M0SRM
Quansheng tg-uv2
yaesu FT-7900E
Motorola DP3600 UHF + VHF
MTH800
MTP850s
SRH3800
CM-9000
MTM5400
paulears
Call Sign: G4RMT
Post by paulears » 17 Jun 2018, 10:12
When my band go abroad, somewhere will be a few radio packs for the guitars - which usually are NOT legit for countries outside europe, operating on EU frequencies rather than elsewhere, plus a few walkie talkies for general comms. In most transits, the guitar cases get looked at the packs pulled out and examined, and nobody has ever noticed the band issues, but the walkie talkies in the suitcases never even generate a comment - so I assume they're more common than we imagine.
26TM5890
Post by 26TM5890 » 17 Jun 2018, 12:21
no issues as i travel between Spain and UK with my Icom ID51 (inc batteries), Icom IC-7000 and MacBook Pro a couple times a year as hand luggage
just make sure that you take it all out for the x-ray
also have a copy of my license just in case but never ever asked for it
so you will be fine
elliotg
Post by elliotg » 21 Jun 2018, 09:01
Thank you all for your replies very appreciated.
Realistic PRO-2006
Farty
Post by Farty » 21 Jun 2018, 18:31
I regularly take my Tecsun PL660 abrpadmin my hand luggage and its never once raised an eyebrow.
Users browsing this forum: Google [Bot] and 6 guests
