Ofcom WTR info
- DX-Digger
- Call Sign: TM205
Ofcom WTR info
Now this new eu data protection rule has been implemented, does this now mean that we can no longer search for radio data on Ofcom's website?
I cannot find the search facility anymore.
Or have they moved it elsewhere??
Re: Ofcom WTR info
You can still access it but not the way it used to work.
If you are on Facebook there is a group (wtr browser) which has been created for this reason. The owner has developed a program to use the data and show the results.
2M0SRM
Quansheng tg-uv2
yaesu FT-7900E
Motorola DP3600 UHF + VHF
MTH800
MTP850s
SRH3800
CM-9000
MTM5400
Quansheng tg-uv2
yaesu FT-7900E
MTH800
MTP850s
SRH3800
CM-9000
MTM5400
- Metradio
- Call Sign: G7HID
Re: Ofcom WTR info
Seems Ofcom are still adding to their database, found a temporary licence (1 May to 30 May) for two multi channel systems covering the royal wedding located in Windsor Castle ...
Mike
Mike
- DX-Digger
- Call Sign: TM205
Re: Ofcom WTR info
ohh ok thanks for the info will look on Facebook then.
- thelad
Re: Ofcom WTR info
I expect GDPR will kill the WTR off over the next month. I have a link to that WTR browser ill pm you it. Foc :-))
Uniden UBC120XLT
Uniden USC230E
Uniden UBC3500XLT
Binatone PMR MR500 x2
Magiksun TM-490 (BF-888) x3
Baofeng BF-888
TTI TSC 100R
Baofeng UVB5
Zastone D900
Icom IC-R6
Uniden USC230E
Uniden UBC3500XLT
Baofeng BF-888
TTI TSC 100R
Baofeng UVB5
Zastone D900
Icom IC-R6
- New User
Re: Ofcom WTR info
Can anyone help by telling me any info on a digital allocation in Southend on sea since December onwards ?
It’s using the nexedge system
Need to know the freq
- Call Sign: G4RMT
Re: Ofcom WTR info
I suspect that when you take your licence out, it's normally tradable - so you are giving permission for your details to be made public. ~For info - the thing that is broken is simply the entry into the system - if you cached any previous searches, the URL contains the information you need to run the search. I've been using it continuously perfectly well. The data is available because it's valuable. I suspect the new data regulation rules are not contravened by the WTR data.
- thelad
Re: Ofcom WTR info
The new data regs require a system where the data can be easy accessed and can be edited by users. The WTR site does not support that.
Uniden UBC120XLT
Uniden USC230E
Uniden UBC3500XLT
Baofeng BF-888
TTI TSC 100R
Baofeng UVB5
Zastone D900
Icom IC-R6
Uniden USC230E
Uniden UBC3500XLT
Baofeng BF-888
TTI TSC 100R
Baofeng UVB5
Zastone D900
Icom IC-R6
- Metradio
- Call Sign: G7HID
Re: Ofcom WTR info
Wipe the egg off your face
Mike
- thelad
Re: Ofcom WTR info
Not sure what you mean there? As i said the WTR has gone and the new Ofcom portal system makes it so they comply to the GDPR.
Uniden UBC120XLT
Uniden USC230E
Uniden UBC3500XLT
Baofeng BF-888
TTI TSC 100R
Baofeng UVB5
Zastone D900
Icom IC-R6
Uniden USC230E
Uniden UBC3500XLT
Baofeng BF-888
TTI TSC 100R
Baofeng UVB5
Zastone D900
Icom IC-R6
- DX-Digger
- Call Sign: TM205
Re: Ofcom WTR info
Thanks I did find it
- thelad
Re: Ofcom WTR info
New portal is here
https://www.ofcom.org.uk/spectrum/infor ... ion-portal
Uniden UBC120XLT
Uniden USC230E
Uniden UBC3500XLT
Baofeng BF-888
TTI TSC 100R
Baofeng UVB5
Zastone D900
Icom IC-R6
Uniden USC230E
Uniden UBC3500XLT
Baofeng BF-888
TTI TSC 100R
Baofeng UVB5
Zastone D900
Icom IC-R6
- thelad
Re: Ofcom WTR info
Works a bit better than the WTR!
Uniden UBC120XLT
Uniden USC230E
Uniden UBC3500XLT
Baofeng BF-888
TTI TSC 100R
Baofeng UVB5
Zastone D900
Icom IC-R6
Uniden USC230E
Uniden UBC3500XLT
Baofeng BF-888
TTI TSC 100R
Baofeng UVB5
Zastone D900
Icom IC-R6
- Call Sign: G4RMT
Re: Ofcom WTR info
....... but is sadly flawed. Use it to check some of your local known radio sites, and you'll discover that the simplification of the lat and long/NGR location data has been used to generate the addresses NOT the real licence data, so you get (in my area) Norfolk constabulary transmitting from a private house 5 minutes walk from the Police station, and a taxi firm operating from a Council House, that ironically has a discone one the roof - yet is nothing at all to do with the taxi firm. oops!
