Ofcom WTR info
DX-Digger
Call Sign: TM205
Ofcom WTR info
Post by DX-Digger » 03 May 2018, 13:52
Now this new eu data protection rule has been implemented, does this now mean that we can no longer search for radio data on Ofcom's website?
I cannot find the search facility anymore.
Or have they moved it elsewhere??
scottyboy
Re: Ofcom WTR info
Post by scottyboy » 03 May 2018, 14:39
You can still access it but not the way it used to work.
If you are on Facebook there is a group (wtr browser) which has been created for this reason. The owner has developed a program to use the data and show the results.
2M0SRM
Quansheng tg-uv2
yaesu FT-7900E
Motorola DP3600 UHF + VHF
MTH800
MTP850s
SRH3800
CM-9000
MTM5400
Metradio
Call Sign: G7HID
Re: Ofcom WTR info
Post by Metradio » 03 May 2018, 14:51
Seems Ofcom are still adding to their database, found a temporary licence (1 May to 30 May) for two multi channel systems covering the royal wedding located in Windsor Castle ...
Mike
DX-Digger
Call Sign: TM205
Re: Ofcom WTR info
Post by DX-Digger » 03 May 2018, 15:26
ohh ok thanks for the info will look on Facebook then.
thelad
Re: Ofcom WTR info
Post by thelad » 03 May 2018, 15:47
I expect GDPR will kill the WTR off over the next month. I have a link to that WTR browser ill pm you it. Foc :-))
Uniden UBC120XLT
Uniden USC230E
Uniden UBC3500XLT
Binatone PMR MR500 x2
Magiksun TM-490 (BF-888) x3
Baofeng BF-888
TTI TSC 100R
Baofeng UVB5
Zastone D900
Icom IC-R6
Mrwoosh
New User
New User
Re: Ofcom WTR info
Post by Mrwoosh » 03 May 2018, 17:46
Can anyone help by telling me any info on a digital allocation in Southend on sea since December onwards ?
It’s using the nexedge system
Need to know the freq
paulears
Call Sign: G4RMT
Re: Ofcom WTR info
Post by paulears » 03 May 2018, 18:18
I suspect that when you take your licence out, it's normally tradable - so you are giving permission for your details to be made public. ~For info - the thing that is broken is simply the entry into the system - if you cached any previous searches, the URL contains the information you need to run the search. I've been using it continuously perfectly well. The data is available because it's valuable. I suspect the new data regulation rules are not contravened by the WTR data.
thelad
Re: Ofcom WTR info
Post by thelad » 03 May 2018, 21:42
The new data regs require a system where the data can be easy accessed and can be edited by users. The WTR site does not support that.
Uniden UBC120XLT
Uniden USC230E
Uniden UBC3500XLT
Baofeng BF-888
TTI TSC 100R
Baofeng UVB5
Zastone D900
Icom IC-R6
Metradio
Call Sign: G7HID
Re: Ofcom WTR info
Post by Metradio » 31 May 2018, 20:27
thelad wrote:
03 May 2018, 15:47
Wipe the egg off your face :D
Mike
thelad
Re: Ofcom WTR info
Post by thelad » 01 Jun 2018, 07:34
Not sure what you mean there? As i said the WTR has gone and the new Ofcom portal system makes it so they comply to the GDPR. :ugeek:
Uniden UBC120XLT
Uniden USC230E
Uniden UBC3500XLT
Baofeng BF-888
TTI TSC 100R
Baofeng UVB5
Zastone D900
Icom IC-R6
sec1223
Re: Ofcom WTR info
Post by sec1223 » 01 Jun 2018, 10:38
DX-Digger wrote:
03 May 2018, 15:26
https://www.facebook.com/groups/wtrbrowser/
cant stand IGNORANT b******ds
DX-Digger
Call Sign: TM205
Re: Ofcom WTR info
Post by DX-Digger » 02 Jun 2018, 12:00
sec1223 wrote:
01 Jun 2018, 10:38
DX-Digger wrote:
03 May 2018, 15:26
Thanks I did find it :thumbup:
thelad
Re: Ofcom WTR info
Post by thelad » 02 Jun 2018, 12:22
Uniden UBC120XLT
Uniden USC230E
Uniden UBC3500XLT
Baofeng BF-888
TTI TSC 100R
Baofeng UVB5
Zastone D900
Icom IC-R6
thelad
Re: Ofcom WTR info
Post by thelad » 04 Jun 2018, 07:51
Works a bit better than the WTR!
Uniden UBC120XLT
Uniden USC230E
Uniden UBC3500XLT
Baofeng BF-888
TTI TSC 100R
Baofeng UVB5
Zastone D900
Icom IC-R6
paulears
Call Sign: G4RMT
Re: Ofcom WTR info
Post by paulears » 04 Jun 2018, 08:26
....... but is sadly flawed. Use it to check some of your local known radio sites, and you'll discover that the simplification of the lat and long/NGR location data has been used to generate the addresses NOT the real licence data, so you get (in my area) Norfolk constabulary transmitting from a private house 5 minutes walk from the Police station, and a taxi firm operating from a Council House, that ironically has a discone one the roof - yet is nothing at all to do with the taxi firm. oops!
Users browsing this forum: No registered users and 8 guests
