Help
Help
Hi.
I know that alot of the radio waves are going digital gradually, and you cant listen to what you could 10 years ago, but im really stuck
All i'm listening to is a few security guards, taxi and air
I would really love to enjoy scanning as it seems a great hobby, and there is probably tonnes of stuff to listen to, but where?
What can I listen to on the lower bands? (1mhz - 30mhz) Where can I find TV audio, and possibly military air etc.
Thanks in advance for any help
Knoxville.
Knoxville.
- Andy
Hi Knoxville. The bands from about 5 to 15 Mhz are full of signals, mainly broadcast AM and 'utility'ssb (mainly amateur, air and maritime). If your scanner has these modes and is a decent performer, you should easily find something. The trouble with most handhelds is that they have poor selectivity (making stations swamp each other) and can only receive the stronger signals. Usually, any attempt to use a nice big antenna causes them to overload and all you get is a mess.
As for VHF and UHF, why not get yourself a copy of the UK Scanning Directory? I think its advertised in Short Wave Magazine - or RadioUser as it is now called.
Don't give up - I've been scanning for about 20 years and was a SWL before that and I'm still finding stuff to earwig on. Half the fun is finding it!
EDIT: Try http://www.ukmidlandscanner.co.uk/index.htm and download the beginners guide, that might help you.
Oops EDIT Again: Were you asking for Wilkinson's freq's? According to my RADIO TODAY CD, you should try: 461.400 MHz and 442.800 nFM. Good luck!
TV Audio
You will find Beeb1 @ 863.2500 and ITV @ 493.2500 still searching for others. you could look @ the links below I found a few for my area in them http://www.scannerfreqs.co.uk/downloads.html
http://www.ajpotts.fsnet.co.uk/links.html
Good luck
Good luck
- Andy
- Andy
Hi again K -
I've looked up Sutton Coldfield, and the channels are:
BBC1 : Channel 46 Sound = 677.250 MHz
BBC2 : Channel 40 Sound = 629.250 MHz
ITV : Channel 43 Sound = 653.250 MHz
Ch4 : Channel 50 Sound = 709.250 MHz
This is an unusual channel layout, so I'll double check and come back with any corrections
- Andy
K -
Hmmm, sounds a bit strange - if you are within Sutton Coldfields area, it should be very strong! I can't imagine why it is weak... unless:
a. Your scanner is busted
b. You have got the attenuator on
c. Your antenna is baaaaaad
Any of the above might also explain why you are not hearing much on other frequencies too!
Sorry, I can't help with frequencies in the midlands - all my stuff is for Manchester.
- Andy
Still sounds a bit 'deaf' to me - although you may be at the edge of Sutton Coldfield's coverage.
Here are some freqs for you:
173.800 to 175 MHz - Radio microphones. They are only a few milliwatts output, but they can be heard over quite an area *if you have a decent antenna*.
There are also other allocations for radio mics around 200 MHz and 800 MHz.
853 to 866 MHz - cordless headphones. There's one around here so I can hear what they have on their TV - interesting late at night!
446/447/427/469 MHz (freq approx) studio talkback links, they come and go. Also worth a listen around 141 MHz.
31 MHz - latest cordless phones.
Hope this helps, but most of these signals are none-too-strong and you may not hear them on a ducky.
