DMR radio programming question
elliotg
Post by elliotg » 24 Apr 2018, 16:25
Hi all
Can anyone help? I have a Whistler TRX-1 and pick up a user on the following details
RX frequency 456.7250
Colour code 5
Group 90
I put this data into my Tytera MD380 and no audio came through at all. I have checked all data has been entered correctly. Any ideas would be great.
Elliot
Realistic PRO-2006
moj
Re: DMR radio programming question
Post by moj » 24 Apr 2018, 16:51
Ras might be enabled and if not make sure the slot is programmed in correctly aswell .
elliotg
Post by elliotg » 24 Apr 2018, 17:17
Yeah i never really knew about RAS until reading about it the now. I guess that is out the door then as the MD380 as far as i know doesn't have RAS.
Thanks for your help mate
Realistic PRO-2006
scottyboy
Post by scottyboy » 24 Apr 2018, 17:30
Ras is a Motorola only function.
If you have dsd+ latest version it shows if ras is in use.
It can’t decode the ras key
2M0SRM
Quansheng tg-uv2
yaesu FT-7900E
Motorola DP3600 UHF + VHF
MTH800
MTP850s
SRH3800
CM-9000
MTM5400
elliotg
Post by elliotg » 24 Apr 2018, 17:46
Cheers for info bud.
Realistic PRO-2006
moj
Post by moj » 24 Apr 2018, 17:57
and also even tho its a Motorola function and if it is enabled you still can't hear the audio without the correct ras key even with a Motorola radio and nope tyt radios don't bypass this check either .
elliotg
Post by elliotg » 24 Apr 2018, 18:12
Oh well at least i can hear it on TRX-1.
Cheers for quick replies guys
Realistic PRO-2006
jhampton2000
Post by jhampton2000 » 24 Apr 2018, 19:18
Elliot - two things spring to mind: (1) RAS that has already been covered by others, but also (2) are you 100% sure you have programmed the Tytera correctly? I assume the channel you are listening too is a DMR repeater. Many people forget that to monitor a repeater channel with a DMR transceiver, you must program the TX frequency to be different to the RX (456.725) frequency.
