SdrPlay RSP2 ?
nordhavn
SdrPlay RSP2 ?
Post by nordhavn » 26 Mar 2018, 16:08
Hi there ,
Any RSP2 users here ?
What sorftware would I need to use it to listen to dmr motoTRBO etc . I've been told its possible and that is need a virtual audio cable etc .
radiosification
Re: SdrPlay RSP2 ?
Post by radiosification » 26 Mar 2018, 16:42
DSD or DSDplus both work. They just listen to the demodulated FM audio and decode from that. Virtual audio cable is simply for routing the audio from the SDR software into DSD so you can use your normal soundcard just to hear the decoded audio. There are plenty of tutorial online you can follow that will be much the same for whichever SDR software you use.
nordhavn
Re: SdrPlay RSP2 ?
Post by nordhavn » 05 Apr 2018, 14:36
Thanks for the reply much apreaciated .
thedeerhunter270
Re: SdrPlay RSP2 ?
Post by thedeerhunter270 » 05 Apr 2018, 14:46
I'm using a RSP1a as we speak to listen to DMR. Works fine.
nordhavn
Re: SdrPlay RSP2 ?
Post by nordhavn » 07 Apr 2018, 14:04
What software are you using ?
thedeerhunter270
Re: SdrPlay RSP2 ?
Post by thedeerhunter270 » 07 Apr 2018, 14:26
I'm using SDRUno with Virtual Audio cable fed into DSD+. Had a bit of trouble finding how to output to VAC, but once I'd found it, it all works well.
nordhavn
Re: SdrPlay RSP2 ?
Post by nordhavn » 30 Apr 2018, 19:55
thedeerhunter270 wrote:
07 Apr 2018, 14:26
I'm having trouble getting mine to work . I'm new to sdr and taking a while to get used to.
