Is 'Close Call' on my Uniden 3500 faulty?
Ninjapower
Post by Ninjapower » 08 Jan 2018, 22:47
Hi all,
Tearing my hair out with this one...
I have a 3500XLT which I have lightly used for a few years now, and it has always appeared to work great. I mostly use it for listening to the local airport, and at weekends I use it to receive PMR446 and other UHF handheld radio at a shoot that I work at.
So I know it receives well and scans as it should, but I cannot seem to get a single flicker of life out of the Close Call facility, which is annoying as I need it for something.
The shoot management have acquired a bunch of new Mitex radios for the guys in charge to use, and I need to find out what the frequency they use is so I can add it to my scanner so that I can listen to their comms as well during the day. The Mitex radios look like your standard 5 watt UHF or VHF 'Business' radios with no display and just a knob on top to select from one of 16 channels or so.
No problem I thought, I just switched on Close Call on the 3500 and got absolutely nothing...
I was anywhere from 5 metres to 100 metres away from the guys using the radios and close call picked up nothing. I checked all the settings, set it to Close Call Priority, and didn't get a thing.
The scanner was picking up the guys using PMR446 a mile or so away, but wouldn't respond to the Mitex radios only a few metres away.
I tried close call again tonight by keying up a 5 watt handheld on UHF and VHF nearby my 3500, and again not a flicker.
What's going on?
Any ideas?
gmham
Call Sign: 108TM154
Re: Is 'Close Call' on my Uniden 3500 faulty?
Post by gmham » 09 Jan 2018, 01:34
I am sure on the Uniden ubc72xlt you used to be able to switch what bands you wanted close call to work with but you say you have everything switched on regards this ? poss try a soft reset ?
http://marksscanners.com/3500/3500.shtm ... ose%20call
god I thought my little uniden 72xlt menu system was complicated, I see the 3500 has loads off option regards close call set up ?!
.... Icom IC7300 HF /6 mtr
Kenwood TR751e 2mtr ssb
108-TM-154 - John
thelad
Post by thelad » 09 Jan 2018, 05:30
I test my CC at the local airport as it works by signal strength and not distance, I can pick up a aircraft on it at just short of one mile away (depending on conditions) with a Watson Supergainer. Mitex do PMR446 handys are you sure it is not them you are picking up already? Other than that they will be on a UK Simple light frequency. Find them here with the tones
https://ukradioscanning.com/viewtopic.php?f=8&t=438
Uniden UBC120XLT
Uniden USC230E
Uniden UBC3500XLT
Binatone PMR MR500 x2
Magiksun TM-490 (BF-888) x3
Baofeng BF-888
TTI TSC 100R
Baofeng UVB5
Zastone D900
Icom IC-R6
DrumGeek
Post by DrumGeek » 11 Jan 2018, 15:19
Could the new radios be DMR?
Uniden UBCD3600XLT| Uniden UBC780 XLT | Commtel COM215 | Realistic Pro-35 | Realtek RTL820 SDR x4 | SDR Play RSP2 | PiAware/Flightaware ADS-B Receiver | Yaesu FT-817ND | Wouxun KG-UV8D | Tytera MD-380 | Anytone AT-D868UV
thelad
Post by thelad » 11 Jan 2018, 18:32
DrumGeek wrote:
11 Jan 2018, 15:19
Could be as Mitex do have DMR handys on sale now.
Uniden UBC120XLT
Uniden USC230E
Uniden UBC3500XLT
Baofeng BF-888
TTI TSC 100R
Baofeng UVB5
Zastone D900
Icom IC-R6
gmham
Call Sign: 108TM154
Post by gmham » 11 Jan 2018, 19:54
Thing is he is saying QUOTE " " I tried close call again tonight by keying up a 5 watt handheld on UHF and VHF nearby my 3500, and again not a flicker ""
108-TM-154 - John
