baofeng uv-5r software wanted please
WARLOCK
Call Sign: 26TM134
Post by WARLOCK » 14 Nov 2017, 19:03
anyone know where i can download the programing software for the baofeng uv-5r radio please,
26TM931
Re: baofeng uv-5r software wanted please
Post by 26TM931 » 14 Nov 2017, 21:25
Down load Chirp !
Mikel
Post by Mikel » 14 Nov 2017, 21:31
Yes I agree, chirp should work ok, used it on a Wouxun KG-UVD1P with no problems:
http://chirp.danplanet.com/projects/chirp/wiki/Home
Post by Admiral » 17 Nov 2017, 08:43
I use CHIRP on my 3-Rs and 5-Rs and it works just fine.
WARLOCK
Call Sign: 26TM134
Post by WARLOCK » 18 Nov 2017, 15:40
Have downloaded CHIRP but finding it very hard to understand am using a baofeng uv-5r radio and windows 7 home premium , service pack 1, i have tried 2 cables NO 1 = the one i got with the radio USB-5R , NO 2 = MAXON that come with a puxing 777 what ever i try all i keep getting when i try to connect the radio to computer is = fail connect with transceiver. ??? any thoughts please
Post by Admiral » 18 Nov 2017, 19:16
This might help.
http://bfy.tw/F6vA
paulears
Call Sign: G4RMT
Post by paulears » 19 Nov 2017, 08:13
If you don't have an older computer, then you need to download the older windows drivers for XP or Vista, then install these on your Windows machine. It will object because the one it has is newer (and doesn't work), make it install the old one, programme the radio and then get grumpy, because the next time you plug in the cable, windows will notice the old driver and put back the non-working one. This is normal and a real pain - but you do get quicker at doing the driver install after thirty or forty time.
Auldgeek
Post by Auldgeek » 20 Nov 2017, 15:49
paulears wrote:
19 Nov 2017, 08:13
:lol: I have a folder that contains the old driver for that very thing! Yes, a royal pain in the ass.
Amateur Callsign GM0BRJ
Tango Mike Callsign 108TM144
