NASTY TETRA
Brownie2k2001
Re: NASTY TETRA
Post by Brownie2k2001 »
I've come across one TETRA signal that doesn't belong to the Emergency Services in Greater Manchester, but i've not got all the software installed, so i wouldn't know if its encrypted or not.
Metradio
Call Sign: G7HID
Re: NASTY TETRA
Post by Metradio »
What part of Manchester and what frequency ?
Mike
Brownie2k2001
Re: NASTY TETRA
I'm in Eccles (Technically Salford) west Manchester.
PM me for the freq, maybe you'll be able to hear it?
Scott_93
Call Sign: Sunray20Alph
Re: NASTY TETRA
Post by Scott_93 »
There is at least one unencrypted network in Manchester, which is Oldham council.
TETRA is in use in some places such as Prisons, Shopwatches (Cardiff I know of), Nottingham Trams, F1 teams (not sure if they are running crypto on all TG's), London underground's CONNECT and on bigger events (such as Commonwealth) they brought in a hired TETRA net.
The only realistic option for trunking, apart from MPT1327, was TETRA. Now DMR T3 and capacity plus/max is taking the place of TETRA, with a generally cheaper price tag.
I don't get why people won't share where networks are, the MNC/MCC/Freqs/TG's I can understand, but even the existence of them?!
Scott.
Metradio
Call Sign: G7HID
Re: NASTY TETRA
Post by Metradio »
Does anybody have any information on LU Connect TETRA system ??
Mike
Brownie2k2001
Re: NASTY TETRA
Scott,
The one i found here is on 442.5400. Spectrum search shows it as:
Arqiva Ltd & Airwave Solutions Ltd
The thing is, it falls way out of the area you'd expect airwave to be. What do you think it is?
Metradio
Call Sign: G7HID
Re: NASTY TETRA
Post by Metradio »
Can you double check the frequency please? as it not a standard frequency and the WTR has no record :)
Mike
Brownie2k2001
Re: NASTY TETRA
My mistake, i keep putting 442 instead of 422... habit i suppose seeing as i don't usually check that low.
It's 422.5400
Metradio
Call Sign: G7HID
Re: NASTY TETRA
Post by Metradio »
In London AFAIK that is one of a number of frequencies used by Airwave as an addition to 380 - 400MHz allocation..
Mike
Scott_93
Re: NASTY TETRA
Post by Scott_93 »
Pretty sure that's Oldham council, their net covers quite a large area (presumably because it's up in the moors somewhere).
When the Olympics were in town I was getting a fair bit of traffic in 422 which was Old Trafford on the actual Olympic net and Oldham council. It's held by Ariqua with a pool of frequencies than can be used as they see fit, sometimes for commercial nets they supply, sometimes as Airwave overflow freqs. IIRC there was a mandatory update that went out on Airwave to include 422 in the band plan of terminals to cope with the temporary cells that were deployed.
There was rumours of a TETRA net at Manchester airport but I've been monitoring the two Airradio MPT nets and they're still going strong with all users accounted for, so think it is just a rumour.
Scott.
yagiman
Re: NASTY TETRA
Post by yagiman »
Does anyone know if TMO will be in the next update?
bigbloke
Re: NASTY TETRA
Post by bigbloke »
Metradio - 100 miles ?
milton keynes safety net
Cabot circus in Bristol
Cardiff safety net & millenuim stadium (might just be over 100 miles?)
Airbus industries (newport) formerly EADS
and a good few prisons
Regards
BB
stratocaster
Re: NASTY TETRA
Post by stratocaster »
yagiman wrote:Does anyone know if TMO will be in the next update?
There was a rumour some time ago about this, but it's gone quiet on that, so I'd say it's highly unlikely.
Metradio
Call Sign: G7HID
Re: NASTY TETRA
Post by Metradio »
bigbloke wrote:Metradio - 100 miles ?
Thanks..
Mike
yagiman
Re: NASTY TETRA
Post by yagiman »
I don’t understand the new update it says on the AOR website it’s a TVD
And on the photo it says it’s a Tetra traffic channel plus
Does anyone know what more this new update will do
