Zastone D900 DMR ?
gmham
Call Sign: 108TM154
Re: Zastone D900 DMR ?
Post by gmham » 27 Dec 2016, 08:31
Okay noted thanks.
I see from the info I had for the shopwatch channel the group entry had the number " 16776415" I don't see this number entered within the info panel , is it just simply group 1 ?
As I say will write everything out as above and see how I get on.
.... Icom IC7300 HF /6 mtr / Alinco DX70TH HF/6mtr / Kenwood TR751e 2mtr ssb... / Inrico TM7.
Ameritron ALS-600X SS HF Linear.... Cushcraft R6000 HF vertical / Hamtenna 80-10 mtr ocf dipole....... / Vine 5ele 6mtrs / Vine 10ele for 2mtrs.
Behringer xm8500 mic.
108-TM-154 - John
f4phixeruk
Post by f4phixeruk » 27 Dec 2016, 20:45
Just tried this out on the TRX-2 and it comes up as TG 1 in the limit search, and the spectrum sweeper
Post by Admiral » 27 Dec 2016, 22:11
That number sounds like an RID.
bigboyblue
Post by bigboyblue » 27 Dec 2016, 22:23
gmham wrote:Okay noted thanks.
that's a radio ID - and its used by any computer application attached to a radio.
it will be smartPTT or more commonly TRBO.NET.
If you use dsd you will see lots of tx and rx from that ID - the computer sits asking the subscriber radios 'are you switched on and in range'.
Be aware that the standard module in TRBO.NET will automatically attempt to stun off any radio that's not in its 'range' they use. Not sure if the zastone radio can be stunned ?
gmham
Call Sign: 108TM154
Post by gmham » 28 Dec 2016, 07:39
Oh how frustrating is this at times ?! at the risk off coming across as a total numpty guys anyone bear with me just a bit longer as seem to have come to a halt in programming in the above for my local shopwatch ch ?!
okay within the CPS dmr2 software on the left hand side I go down to " Channels information " when I expand this I get a large list off programmed channels say " su16 right down to GG420 " I am not sure how if I can simply add to this channel list with the local shopwatch ch or I have to edit one off the already programmed channels ? I tried editing one off the channels but when I try at the scan list entry it only gives a choice off " none or a 4 GB7 channels " how do I select scan list 1 in this field ?
108-TM-154 - John
Post by Admiral » 28 Dec 2016, 09:10
Hover the curser over the 'Channels Information' folder, right-click and 'ADD' for a new channel. If you're doing a couple of channels with the same info but just a different TS then once one channel is done, single-click the channel on the left pane to highlight, right-click and COPY, then left-click on the next new channel down and right-click and PASTE, you can then do any minor alterations to the second channel manually.
You need to make yourself a new scanlist to scan the shopwatch (if you are using both TS), then best prcatice of making a new ZONE to put it in to keep it away from the other junk if your just in a SW mood, or lump it in with others on a different zone if you want a general scan of different channels.
gmham
Call Sign: 108TM154
Post by gmham » 28 Dec 2016, 18:58
Okay thanks yet again for your continued help guys, at this point I must say I am not finding things easy with the DMR side off things and must admitt to being envious off you others who seem to pick it all up so much easier !! going to give it a few days longer and if no joy then anyone looking for a brand new D900 please get in touch !!!
okay tried to add a new channel in my case 110 off 110, entered the shopwatch info as above and yet when it comes to the " group list field " the drop box gives a choice off " none, uk calls or TG9 S1 " how do I edit it to group list 1 ?
HELP ,,,,,,.,!!!!!!!!
108-TM-154 - John
Post by Admiral » 28 Dec 2016, 19:36
Don't give up, if a thicko like me can do it then anyone can. Does grouplist1 exist? if so then it should show on the dropdown in the channel. It can be a bit confusing when starting a codeplug from scratch as you need to create all your channels without the scanlist or grouplist (because the channels don't exist yet), then create the scanlist and grouplist, then go back to the channels and assign the grouplist and scanlist, a bit chicken and egg.
Are you starting from scratch? Sounds like you may have a generic ham codeplug in there which can be very confusing, personally I'd start a new one (but obviously save the current one)
If you post the frequency, CC and any TGs I can knock you up a quick 1 zone, 2channel (both TS) codeplug for your SW, you can then have a look at it to see how it was done.
gmham
Call Sign: 108TM154
Post by gmham » 28 Dec 2016, 20:13
Okay cheers have sent you a pm as will take you up on your kind offer to knock me up a new code plug with the two shopwatch channels required and maybe if oaky with yourself 8 x 446 MHz analogue channels and 8 x 446 MHz DMR channels. the code plug that I downloaded from the net obviously had all the amateur radio DMR channels but in all honest was not off any real interest to me.
thanks so much.
john
108-TM-154 - John
Post by Admiral » 28 Dec 2016, 20:37
As discussed, just the SW in this one so you can see the structure and the relationship between all of the required info.
SW.zip
gmham
Call Sign: 108TM154
Post by gmham » 28 Dec 2016, 21:16
that's superb will download and have a play tomorrow after work. as always it's very much appreciated, thank you.
108-TM-154 - John
thelad
Post by thelad » 30 Dec 2016, 08:25
It aint as easy as you think, took me a week of tinkering to get to grips with the basics.
Uniden UBC120XLT
Uniden USC230E
Uniden UBC3500XLT
Binatone PMR MR500 x2
Magiksun TM-490 (BF-888) x3
Baofeng BF-888
TTI TSC 100R
Baofeng UVB5
Zastone D900
Icom IC-R6
gmham
Call Sign: 108TM154
Post by gmham » 31 Dec 2016, 12:15
Okay thanks so much to you guys have managed to convince myself to hold on that bit longer with this DMR side off things ! have even installed the Saar edition FW and watced a few more videos so hopefully this time next year I may even be able to programme in one off my own ch`s !!
okay want to try the front keypad direct entry, can I enter the 8 446mhz analogue freqs straight in ? not sure if you can switch from annalogue to digital via the front keypad method ?
108-TM-154 - John
Post by Admiral » 31 Dec 2016, 12:33
I don't think you can program it from the front (I may be wrong as never tried it) I think you can only edit existing information.
My 446 zone has 1-8 without scan, and I put in CH9 which scans 1-8, that way it doesn't whizz off scanning when a hit comes in, if you want to carry on listening or talk back then turn the dial on top to the channel that CH9 scan channel found the hit, hmmm, hope that makes some sort of sense.
gmham
Call Sign: 108TM154
Post by gmham » 31 Dec 2016, 13:57
Okay thanks your right no front panel programming available for non programmed channels.
Okay I now have the two shopwatch channels working fine thanks to your codeplug so that brilliant very impressed with the quality off the received audio.
Okay want to add the 8 analogue 446mhz channels next. Thought it would be a case off opening up the channel info and adding an analogue channel and writing it to the radio as channel number 3 but nope .
Any chance off a quick run down on adding the 446mhz 8 analogue channels with scan to the codeplug you supplied ?
108-TM-154 - John
