Go north east buses
- New User
Go north east buses
Hi guys, this is my first post so go easy . I'd just like to ask what the frequencies are for go nirth east. I have most of the depots, but can't seem to hear anything from the drivers, just control replying to them. Any ideas? Thanks
Re: Go north east buses
are you aware of the ofcom database and how to use it?
if not go to
http://spectruminfo.ofcom.org.uk/spectrumInfo/licences
sort of licence business, then for this purpose technically assigned
what ever your frequency range is you want to search then select MHz
then on the map zoom in and use the select area cross at the top, click on it and drop it in the middle of your search area, then left click and expand it out to make the search area wider.
then click submit search.
if not go to
2M0SRM
Quansheng tg-uv2
yaesu FT-7900E
Motorola DP3600 UHF + VHF
MTH800
MTP850s
SRH3800
CM-9000
MTM5400
Quansheng tg-uv2
yaesu FT-7900E
MTH800
MTP850s
SRH3800
CM-9000
MTM5400
- thedeerhunter270
For analogue try.
163.3250
163.4250
163.3250
163.4250
- New User
scottyboy wrote:are you aware of the ofcom database and how to use it?
if not go to
Thanks man, I'll have a look
UPDATE: It seems like this is more of a finding a needle in a haystack operation, I cannot find the company's frequencies
This is my understanding: The bus company will likely have a TX frequency (depot transmit) and RX (driver transmit, depot receive).
I search the WTR like this: say the frequency I'm getting the depot/taxi firm on is 165.125, I search between 165.1 to 165.2. Assuming my search radius is correct, I get the licence holder with their TX and RX frequencies. I program the RX freqs in and if I'm in range, I get the drivers.
Of course, there may be a standard offset from TX to RX freqs (4.8 mhz on the stuff I have in my scanner) which you could apply to the depot freq and see if you hit paydirt.
