Whistler 'Q' - A Revolution In Importing Frequencies
The IDEAL and UNIQUE Companion to your Scanner and EZ SCAN Software
With Whistler 'Q' you can QUICKLY IMPORT frequency lists
from almost ANY source including the Web
No matter what the list looks like
In seconds you can have those Frequencies
ready to upload to your Scanner
Your lists are automatically saved to your P.C.
so you can transfer them at any time
and you have permanent backups
You can FILTER the lists with a Key Word
SORT them into the exact format for EZ SCAN
Remove any lines you do not want
AND
add Default Modes and Scan List numbers
Whistler's EZ SCAN is fantastic software
especially if you are in The U.S. or Canada
because thr RR Database is extensive
HOWEVER
In other parts of the world that Database has few if any entries
Whistler 'Q' FILLS THAT GAP
No matter where you live 'Q' adds a UNIQUE, FAST and VERY EFFECTIVE
way or acquiring frequencies of most types and sources
Download the free trial:
http://whistlerq.wixsite.com/whistlerq
Mike
Whistler Digital Scanner Users in the UK
- Metradio
- Call Sign: G7HID
Recommendations
Some very nice recommendations already arriving at the YouTube site
https://youtu.be/tGfBiz6r1aU
Re: Whistler Digital Scanner Users in the UK
How does the performance and range compare to that of an AOR DV1 or a Uniden BCT536 HP?
got a rxt 1 few days ago cant get it to do nxdn.i have got dmr ok but the main reason was ndxn.any1 help pm me
- Metradio
- Call Sign: G7HID
Write a question here, read the answers here...
The TRX-1 receives and decodes NXDN in Search mode automatically..
When you say you can't get it to do NXDN, are you sure it is an NXDN signal you are trying to receive?
If it is encrypted it will sound Klingon.
Mike
Mike
its cool a got it working took ages of mucking about a thought might be encrypted but nope.thanks
Hi, i got a trx-2 and same as you wanted to scan nxdn, no problem with the whistler, clever piece of kit, put in a wildcard and it found everything i wanted to hear, theres a uk whistler facebook group if you search with some excellent tutorials on the whistler radios
my trx1 wont work on my discone it wont receive a single thing not even my 446 radio but soon as put in the antenna that comes with it it works ok.strange lol the discone works on sdr and my old mvt7100
