whistler ws1098 MOTOTRBO decoding
muk
Re: whistler ws1098 MOTOTRBO decoding
Post by muk » 03 Sep 2016, 14:52
I've been playing quite a bit more today, and while no direct entry is possible afaik it's still reasonably usable. Question is would you pay well over twice the money for that feature (AOR) the more I use it the more I'm getting used to it and think my initial disappointment may have been hasty, but that's not to say there are no downsides and it's not as intuitive to use as some radios. But overall I'm happier than yesterday.
Whistler WS1098
Motorola SL4000
CS701 VHF DMR
Bumfu@k UV-5
Some old random toot
Metradio
Call Sign: G7HID
Post by Metradio » 03 Sep 2016, 17:18
Bottom line, this is the type of scanner you would find in a Police Car in the US, it would be pre-programmed with CB, other agencies etc and would be ideal for that use. It is not designed for the fiddler that likes to have a good old tune around..
Mike
mickydt
Call Sign: 26tm441
Post by mickydt » 03 Sep 2016, 19:25
in a nutshell you will still need a separate system to hunt out dmr signals which sorts of defeats the object, may be one reason why the shop down south stopped me from getting one.
interesting whistler was the code name for windows
supporting those with sickness and disabilities at - https://socialhub.forumotion.co.uk/
Metradio
Call Sign: G7HID
Post by Metradio » 03 Sep 2016, 19:50
It will search to find signals, DMR included, but is more of a scanner than a searcher..
Mike
taximan
Call Sign: 2E0YTT
Post by taximan » 03 Sep 2016, 22:30
Bought a ADCR25 PRO2 from this site http://hrw.3dn.ru/ only two versions vhf and uhf but decodes DMR great.
kurisu
Post by kurisu » 04 Sep 2016, 21:48
As it's not possible to punch in a number. Are you able to search between a frequency set looking for a hit... Such as searching between 440 and 470mhz on a loop just to see if you get somthing and then save it?
This is what I tend to do on my uniden.
Uniden BCT15X
muk
Post by muk » 04 Sep 2016, 22:07
kurisu wrote:As it's not possible to punch in a number. Are you able to search between a frequency set looking for a hit... Such as searching between 440 and 470mhz on a loop just to see if you get somthing and then save it?
Yes you can do that, and once found save something direct to memory
Whistler WS1098
Motorola SL4000
CS701 VHF DMR
Bumfu@k UV-5
sec1223
Post by sec1223 » 05 Sep 2016, 10:48
i hope theres a new version with vfo for xmas time
cant stand IGNORANT b******ds
sec1223
Post by sec1223 » 05 Sep 2016, 10:50
taximan wrote:Bought a ADCR25 PRO2 from this site http://hrw.3dn.ru/ only two versions vhf and uhf but decodes DMR great.
looks good but expencive i think
radiogaga
Post by radiogaga » 05 Sep 2016, 17:59
muk wrote:
Love the remote head, hate the RJ coming out the side
What about one of these for the RJ45?
http://www.ebay.co.uk/itm/CAT5-Cat5e-Ca ... 1cCv_Q9OEg
JLow75
Post by JLow75 » 29 Sep 2016, 14:08
I've got a Radio Shack PRO 668 - which I believe is very similar to the Whistler WS1080 (if not identical in it's features), I am getting absolutely nowhere with it at all! - obviously it came with the memory card loaded with all the US state band plans/trunking systems. Moonraker are stating that they now have UK band-plans on their models? does anyone know how to obtain these? (don't mind paying for them)
This, along with any other information that can get me using this scanner to it's full potential - i.e. Digital recieving/trunking, software to use, UK sources etc will be gratefully received.
Thanks in advance
Metradio
Call Sign: G7HID
Post by Metradio » 29 Sep 2016, 15:06
The UK Bandplan upgrade to the Whistler is via the firmware, so if your PRO668 takes the same firmware (doubtful) it is all on the Whistler web site..
Mike
JLow75
Post by JLow75 » 30 Sep 2016, 07:12
Oh right, I assumed all the band-plans were saved on the memory card. Sorry I am not familiar at all with these new style digital trunking scanners.
Any tuition that could be put on here for such devices would be great.
Metradio
Call Sign: G7HID
Post by Metradio » 30 Sep 2016, 07:59
JLow75
Post by JLow75 » 30 Sep 2016, 11:36
Excellent! thanks.
My PRO 668 has no warranty anyway, as I brought it 2nd hand (but barely used so immaculate) so worth a try.
I have heard though you can permanently lock them out messing with the firmware - rendering them basically a write-off if you don't know what you're doing, so I need to be sure of success!
