taxi split freq ?
- gmham
- Call Sign: 108TM154
taxi split freq ?
Found a local taxi freq on 173,060 mhz can someone remind me what the split is for the base tx ?
Yaesu FTDX10
Kenwood TS711e
Anytone D578UV Pro+
Moxon antenna for 10/20 mtrs
John - 108TM154 / 108CO154
Kenwood TS711e
Anytone D578UV Pro+
- Metradio
- Call Sign: G7HID
Re: taxi split freq ?
Should be -4.8MHz
Mike
Mike
- Mikel
gmham, what radio did you use to receive the taxi on as its a bit of an odd frequency to my eyes? Could it have been 173.0625 and maybe it was 'rounded off' by the 'steps'/bandplan in the radio/scanner?
- RogerD
That frequency is a single one, no pairing. It's "Simple UK Light" - one of about 15 channels you can use on the cheap (small fee) as an alternative to PMR446
- Mikel
Yes that is where my mind was going:
http://ofcom.org.uk/static/businessradi ... mpleUK.pdf
There is a taxi firm in my street that has one of these channels programmed into their radios in addition to the usual technically assigned 'taxi business' frequency so that they can talk car to car 'CB' stylee.
As you correctly state, no split.
Strange but true.
Strange but true.
- gmham
Ah okay thanks for that ! am I correct in saying that no fixed base use is even permitted with the light licence ?
Yaesu FTDX10
Kenwood TS711e
Anytone D578UV Pro+
Kenwood TS711e
Anytone D578UV Pro+
- Mikel
Yes thats correct, the OFCOM doc states:
Technical conditions
The maximum permitted ERP for mobile stations is 5 Watts;
The frequencies listed in this schedule shall be used in single frequency mode only;
The use of base stations is not permitted.
But like I stated a taxi firm near me has used one of these frequencies for general chit chat, car to car and base to car for ages without any problems.
- gmham
Okay thanks so at 5 watts at 173 mhz in mostly built up areas they are not going to achive much in the way off distance then ?! do you get to choose your spot light licence freq or is it allocated ? I know there used to be one on low vhf poss around 86 mhz just wonder if this would have been a better freq to have choosen for car to car use ?
Yaesu FTDX10
Kenwood TS711e
Anytone D578UV Pro+
Kenwood TS711e
Anytone D578UV Pro+
- Mikel
The frequencies are below (as given in the OFCOM doc I posted a link to):
77.6875
86.3375
86.3500
86.3625
86.3750
164.0500
164.0625
169.0875
169.3125
173.0500
173.0625
173.0875
449.3125
449.4000
449.4750
You choose the frequency or frequencies, which are suitable for a given application is open to a great deal of debate!!
77.6875
86.3375
86.3500
86.3625
86.3750
164.0500
164.0625
169.0875
169.3125
173.0500
173.0625
173.0875
449.3125
449.4000
449.4750
- Minus1
Hardly anybody uses the five VHF low frequencies, not heard a peep out of any of them in 6 years!
- RogerD
Bigger aerials aren't cool
