Realistic pro 2006 back light
- Call Sign: Cannonball
Hi
I have a pro 2006 with no back light, is this a common problem?
I do get the normal voltages on the dimmer switch so looks like the transformers etc are fine.
- bigpimp347
Re: Realistic pro 2006 back light
yes very common,
you can buy replacement LED's off ebay from the US about £15 posted.
2005, 2006 and 2022 all suffer after a few years.
- nerdsville
I've replaced the back lights on a PRO2006 and PRO2022, they are electroluminescent (EL) panels and you can buy small sheets (in various colours) which you just cut down to size (making sure when you do to include the contacts) I got mine from ebay (click for link) for just £12
Doing my PRO2022 and the more fiddly PRO2006
and a more detailed step by step guide http://nr8o.dhlpilotcentral.com/?p=153
Sorry nerdsville but I couldn't help commenting on your use of the 'Clit Bang degreaser'.Sounds like interesting stuff right enough.
I've done both my 2006s in quick succession in the past few months.Seems that when you've done one,the second is that little bit easier.
2 X PRO 2006 1 X DX-394 1 X GRE PSR 282 1 X UBC780XLT with ProScan 1 X Pro43 1 X Yaesu FRG 100 Uniden 125 XLT LCL 2740.
- nerdsville
can I blame the spell checker rather than a Freudian slip?bigbassman wrote:Sorry nerdsville but I couldn't help commenting on your use of the 'Clit Bang degreaser'.Sounds like interesting stuff right enough.
Yes, I've ordered a EL back light, from eBay
Do you guys power it from the original source keeping the dimmer button?
Thanks for the link Nerdsville
Keith
Keith
My replacement came from the States already cut to size and involved a bit of dismantling,unplugging stuff,and a couple of nuts and bolts.The actual replacement involved unsoldering 2 little contacts,removing a little bit of glue,sliding out the old display,sliding in the new one and resoldering the new contacts to the existing terminals.Assembly was a reverse of the dismantling process.Everything is then just as it was before,dimmer button included.
Pretty straightforward,but the US seller did include pretty thorough instructions,which helped a lot.
This is where I got mine from http://www.ebay.co.uk/itm/Realistic-Pro ... 5e5&_uhb=1
bigbassman wrote:This is where I got mine from http://www.ebay.co.uk/itm/Realistic-Pro ... 5e5&_uhb=1
Looks like place I ordered mine from, hope gets here soon.
Get scanner second hand, has been modded, has cut diode on back of display board, but has 2 cut not one?
Also has a resistor cut on main board, not sure why as yet
hi guys
i know this is a old post but for anyone who is still after a back light for there realistic scanner i have found this place that are doing them for £5 (half price at the moment )in a choice of colors
it is larger than the original so will need cutting down
ordered one today free post for my 2006 well pleased
all the best
http://elwirecraft.co.uk/el-products/el ... -scanners/
all the best
Good to know.Thanx for that.Fancy colours as well.Thats handy.When you read of the palaver some people go thru just to change the backlight colour on their display.
your welcome bassman
couldn't resist then tron blue myself lol
- tonymagic53
- Call Sign: Shepard
Bought one a couple of days ago for my pro 206 after dynamite40's recommendation, £5 with paypal including vat and posting. 45 minutes fitting (most time trying to find scissors ), works great. thanks for sharing the info dynamite40 .
regards tony
regards tony
your welcome glad to help
- Call Sign: GM4RJX
I've been looking at changing the back light for ages - its barely visible on dim and only a little better on normal. Great post. Still a fiver today.
