Grecom scanner PSR-295
LISSIE1962
New User
New User
Post by LISSIE1962 » 24 Feb 2011, 11:28
Does anybody know how to unblock channels on a PSR-295 Grecom scanner.Many thanks.
rayzor_uk
Re: Grecom scanner PSR-295
Post by rayzor_uk » 24 Feb 2011, 19:47
Do you mean locked out channels
LISSIE1962
New User
New User
Post by LISSIE1962 » 24 Feb 2011, 19:49
LISSIE1962 wrote:Does anybody know how to unblock channels on a PSR-295 Grecom scanner.Many thanks.
rayzor_uk wrote:Do you mean locked out channels
yes i do sorry my mistake.
rayzor_uk
Post by rayzor_uk » 24 Feb 2011, 20:49
Locking Out Channels
To lock out a channel while scanning, press L/OUT when
the scanner stops on the channel. To lock out a channel
manually, select the channel then press L/OUT so L appears.
Note: You can still manually select locked-out channels.
To remove the lockout from a channel, manually select
the channel and press L/OUT so L disappears.
Reviewing the Lock-Out Channels
To review all locked out channels, press MANUAL. Then
repeatedly alternate between pressing FUNC and then
L/OUT to view each locked-out channel. When you finish
reviewing locked-out channels, press MANUAL.
tiuleepa
Post by tiuleepa » 30 Jan 2012, 10:13
How hard is it to program a digital police scanner? I am thinking about buying one but I'm kind of scared to because I have heard that they are really hard to program and I want to know if that is true. I used to have a scanner back in like 1999, before they went digital here and I never had any problem programming the older scanners. I know I can get software for programming it thru a computer, but I'd like to save some cash. Is it real hard to program them manually?
MrWeetabix
Admin
Admin
Call Sign: 26TM175
Post by MrWeetabix » 30 Jan 2012, 11:55
tiuleepa wrote:How hard is it to program a digital police scanner? I am thinking about buying one but I'm kind of scared to because I have heard that they are really hard to program and I want to know if that is true. I used to have a scanner back in like 1999, before they went digital here and I never had any problem programming the older scanners. I know I can get software for programming it thru a computer, but I'd like to save some cash. Is it real hard to program them manually?
There is no such thing as a "Digital police Scanner", its pretty much the whole reason they went digital int he first place. Its now a secure, private network. Listening to Live Police transmissions is not possible, unless you join the force or an affiliated organisation. Fact.
Sorry to be all doom and gloom, but thats just how it is.
