simple PTT/audio interface
welshevo
Call Sign: 163TM995
Post by welshevo » 18 Mar 2018, 20:17
im looking for a simple PTT/audio interface to pass audio from zello through a Sepura SRH (side connector audio accessories port) radio but cant seem to find any info on pin outs etc? do Sepura use the same pin outs as the Motorola MTH side connector? any advice would be amazing....
TRON
Re: simple PTT/audio interface
Post by TRON » 04 Jul 2018, 09:35
Audio port pin out is here: https://sites.google.com/a/digitalradio ... als/sepura
If you download the pin out, it becomes an "orphan" document. Scan the QR code for the latest version (as I find anything interesting, I add it to the website).
Do NOT connect these handsets to other devices whilst on charge. You'll create a ground loop, which means at best, you'll get buzzing noises on the audio. At worst, you'll kill the audio on the handset.
Research audio transformers and relays for the interface. I use 1:1 600ohm audio transformers exclusively. Opto-isolators are solid state alternatives to relays for low current switching.
