hey all , im looking at setting up a ROIP using my linux laptop to stream various sources from GNU Radio ...i was thinking Zello but this doesnt support linux? anything else like it that can stream using linux? and is also avaialble for mobile devices like apple iphone/ipad...
i want to be able to remote listen to my GNU Laptop anywhere instead of being stuck indoors hahaha
linux and ROIP
- welshevo
- Call Sign: 163TM995
linux and ROIP
Re: linux and ROIP
icecast and alsa
Re: linux and ROIP
I'm just starting to look into this too but I want to do it with a dmr hotspot.
I have seen videos of hooking up a radio to a computer using the audio ports in.
I have a cheap virtual private server on the internet that I have a mumble server running on. The server is easy to install and configure, 5 min. You then just set up a client on a computer. The mumble client is vox capable. The Android client is limited but I have been able to stream audio from my phone through my mumble server and broadcast to any device connected to my mumble server. Don't see why it wouldn't work with Zello.
- radiogaga
- Call Sign: 26TM399
Re: linux and ROIP
App is called Plumble save you searching that one out.
GEDSTER314, do you have anything to prevent the VOX latching and permanent transmit?
30TM399 Northern Costa Blanca
