CB RoIP?
rogerbeep
Call Sign: 20TM896
CB RoIP?
Post by rogerbeep » 08 Nov 2016, 23:22
Any suggestions regarding how to set up a CB remote station?
... other than buying commercial interface units and use an amateur tranceiver...
The concept of the CB radio CRT Mike could be possible to "hack" and link for two-way internet communication? Don't ask me how to do it! :(
For those who don't know this radio: CRT Mike has ALL controls and audio built into the mic unit, connected with one single plug to the RF part.
I just want to put an extension cord named "internet" between the two units :)
TRX:
Icom 706 mk II / Icom 735 - Alinco DR-135DX - President Grant mk II / Jackson mk I - CRT SS9900 / One - Anytone AT300M
QYT KT-8900 - Icom F4SR / 28H - Baofeng UV-5R / 888S
RX:
Uniden UBC 780 XLT - Icom R5 / PCR-100 - RTL2832U/R820T + Ham It Up v1.2 - NESDR SMArt
Mad4radio
Re: CB RoIP?
Post by Mad4radio » 12 Nov 2016, 09:36
how you going to control the triggering of the PTT????? VOX???? that would work if the radio supports it if not In the ideal world you really a comport keyer as that's its job to trigger PTT once audio is detected.
rogerbeep
Call Sign: 20TM896
Re: CB RoIP?
Post by rogerbeep » 19 Nov 2016, 19:49
Mad4radio wrote:how you going to control the triggering of the PTT????? VOX???? that would work if the radio supports it if not In the ideal world you really a comport keyer as that's its job to trigger PTT once audio is detected.
PTT shall be triggered with the physical button as normal, I will have the hand unit at my site and the main unit at the remote site.
Look up "CRT Mike" to see/read about the radio I consider for this project. (Mic including speaker and all controls and separate main unit.)
Obviously I need interface units at both ends. It is the construction/programming of these units which is interesting and subject in this thread.
I am not talking about COM-port connection and exchanging information between two ordinary PCs, but a more modern and independant solution like f.i. two Raspberry Pi set up in a (VPN) network.
I should have been more clear about that in the first posting.
Since the CB radio (CRT Mike) internally shares ALL in- and outgoing signals and radio functions via a single connection point, it shall be possible to convert those signals into digital values.
Sound is probably analogue and I might need to make simple AD/DA converters and an small amp for getting sufficient sound at operation side.
All values will be forwarded to the other "computer" where it is coded back to original format and fed into the remote unit. And vice versa.
On/off, PTT, TX/RX audio, channel selector and squelch control shall be connected and decoded via the Raspberry Pi's GPIO-pins ad shared between the two computers.
How to treat and forward the information from/to each GPIO between the two units is the important part in such a project.
In this way I could for instance operate my CB radio via Internet from a friends house in another part of the country - where my old CB friends are living.
I have found some info for similar setups but not with CBs, which are not standarized in the same way.
Hopefully someone at TM1 find such a CB-project interesting and can help pointing further in the right direction.
TRX:
RX:
Mad4radio
Re: CB RoIP?
Post by Mad4radio » 19 Nov 2016, 23:01
sounds abit confusing if I'm allowed to say & way too much work just for a CB ROIP setup, Why not just keep it simple & purchase a ready made & ready to go com-port keyer that would plug straight into the radio & pretty much ready to go once the dedicated com-port has been selected for the interface to control PTT via the software you want to run your ROIP link on??????
I have a similar sort of ROIP setup that your wanting to create with one linked radio located 90 mile away from the other & both sit side by side within a dedicated room on a private server of which can be directly accessed via an RF protocol or 3G/4G mobi phone or Ipad device etc.... should the user choose & both work extremely well & very stable, Both nodes are run on a simplex channel & both operate DMR with capabilities of been put/moved into another room on the server where both could be linked into the rest of the DMR capabilities that we carry i.e our UHF & VHF rptr systems
I think if it's a CB ROIP link your wishing to setup if i'm thinking along the same path as yourself just purchase a rig check the pins at the mic plug end & either configure or purchase a ready to go com-port keyer that will control PTT, Don't worry about the audio as the interface caters for that too as some like mine had x2 jack plugs at the other ends of which plug into your onboard soundcard or external sound card that will allow the incoming & out-going audio to be passed via the radio & of course your VPN or a private server
Regards
rogerbeep
Call Sign: 20TM896
Re: CB RoIP?
Post by rogerbeep » 20 Nov 2016, 01:37
Well, as I indicate in the first posting I want to avoid using my most expensive radio with the additional cost of interfaces to operate remotely.
For instance, Remoterig RRC-1258-series for my Icom 706 has a retail price of close to 500 USD plus my import fees and then 25% tax. That will give me full remote access to that radio, but via an old type of interface even if it is independent from using a computer.
Not to forget: It would be an overkill and waste of money to use such hardware combination as a remote rig at the CB band - because of the total price, and the fact that I will need yet another IC-706 for my shack. :)
I may mislead the readers when using the word RoIP. My intension is to set up a remote controlled CB radio, which only I can use via internet.
Repeater function is not planned, since another radio is needed - but this would of course increase the user value a lot, since I can operate from my car as well.
What kind of com-port keyer are you using for your setup? I am not quite sure if I understand which concept you are talking about. I would like to know more.
My impression is that this might sound like the setup needed to use FRN for typical PMR/DMR radios equipped with a two pin Kenwood-plug.
I could be wrong, but it seems that FRN is not ideal for remote controlling a CB radio actively.
Can you change channels, modulation type, rf gain and adjust the squelch? I cannot do this (yet) but would love to solve the problem! :)
I want to have full remote access to a CB radio situated somewhere else - just as if I was present at the other location.
This involves having the main radio unit at the remote location, and the microphone with all built-in controls/speaker in the palm of my hand when sitting in my own radio shack.
Ideally it shall not be any differences between operating the remote station and to the other radios in the same room.
We might have different approaches and thoughts about RoIP, the grade of networking, third party connection possibilities and types of radio equipment, but still I appreciate all types of feedback, possibilities and suggestions.
TRX:
RX:
mercury888
Call Sign: M6IGP
Re: CB RoIP?
Post by mercury888 » 20 Nov 2016, 09:37
The CRT Mike is a CB in two bits with a lead. It should be possible to extend that via an Internet (or any other) link but that's 'should', not 'will' and it's potentially a heck of a lot of work!
Speaking fairly generically here, you first have to figure out how many wires (not clear from the pics I saw) are in the lead and what they do. Then you need to figure out how they do what they do. For example, let's say there are 4 wires that perform all the functions - there are so many functions that there might be some sequencing to how those wires are used, and we've not even got to what voltages or pulse durations are involved.
If - big if - you can figure that out then you can figure out an interface, probably some diode / transistor interfacing to get the voltages right, and some way to make the sequencing work. If it were me (it isn't!!) I'd be looking at a Raspberry Pi for each end of the link plus control circuitry.
If you managed the above then the rest is programming. For example, you change frequency, the Pi at your end sees the various control signals and sequence and realises what it is, sends that data to the remote Pi which activates the relevant wires in the right order and pulse lengths.
If all the above actually worked then remember you also need top are it fail safe - if your system crashes while on ptt there needs to be something to shut it down. Also consider which bit starts the process - you may need to power the remote bit first before you can even send it any signals - easy to do with a separate o/p from the Pi and a relay...
Take the Pi out of the equation and replace with hard-wired logic and the above is the beginning and end of any such control system.
This is why standards are useful - someone makes a standard interface and tells everyone how it works and what you need to interface to it. Of course for all I know this CRT Mike may even use some standard.
Hard work if you ask me - but should be possible given time, patience, and test gear. In the Old Days I even connected a Nixie readout on an analytical machine to a pre-PC computer via wires and voltage sensors to record what digit was displayed. But that's a walk in the park compared to this...
CB: President Grant II (1980's handle: Bootstrap; now 26TM868)
ADS-B: FR24 T-EGNM-63
Yaseu FT450D; Signal R535; W-SDRX1 + Gnu Radio and CubicSDR
Baofeng UV5R; TYT MD380; Trio TR-9130
Mad4radio
Re: CB RoIP?
Post by Mad4radio » 20 Nov 2016, 12:56
Nice Comment "mercury"
Another thing as well is that all this can be done via a simple program called teamveiwer.......... When I was playing on HF using an FT100 I had it cat cabled up via HRD which could control the freq i wanted to play on as well as PTT Using teamveiwer to remote into the machine the radio was connected too & using skype to relay voice on & worked very well & leaving some folk very impressed with how easy it was to setup to do.
Pretty much the moral of the story is the simple ways do sometimes always seem to work & work well
rogerbeep
Call Sign: 20TM896
Re: CB RoIP?
Post by rogerbeep » 20 Nov 2016, 23:43
Mercury, RPi is described further up in the thread as prefered hardware for the intefaces.
CRT Mike has a TOT - Timeout timer.
Remote shutdown will be initialized when/if control signals are lost (i will include a check routine between the RPis).
In general signals should be easy to decode, since this is a simple an cheap Chinese radio design. I don't know the coding of controls as I need to purchase the radio and analyze, I hoped someone else already did this.
Mad4radio, I am still curious about the questions I asked in my previous posting.
I have HRD but am not sure about if the software accepts transmission outside ham bands even if the radio is capable.
If I use skype or other SIP, I believe I need same setup in both ends.
I have found some descriptions for RPi used for remote operation, I will have to spend time reading that.
Thanks for your feedback so far guys!
TRX:
RX:
Mad4radio
Re: CB RoIP?
Post by Mad4radio » 21 Nov 2016, 12:36
rogerbeep wrote:Mad4radio, I am still curious about the questions I asked in my previous posting.
If your radio is widebanded at both ends & will TX & RX out of band I don't see the problem, The way's of which my links/nodes work are based on commercial gear & using the rear pin-out's on the radio's to connect an accessory connector to the pin-out's that will carry both incoming & outgoing audio as well as controlling PTT using a basic interface purchased from the tinter web.
Regards
